UDF issue when implementing a downstream resistance dependent outlet pressure
Old   October 26, 2017, 11:37
Default UDF issue when implementing a downstream resistance dependent outlet pressure
joe
shiju7279 is on a distinguished road
I am trying to implement the following udf for a simple straight tube model that has laminar flow within it. The desired objective here is to have a flow within the pipe, that is dependent on the downstream resistance. This resistance affects the outlet pressure (P2=resistance*outlet flow). The udf is expected to do this job. However, I am not achieving what I should get.
The inlet pressure is set at 95 mm Hg while the outlet pressure is dependent on this downstream resistance and so this udf is prescribed at the outlet.
I am not sure where I am going wrong. Firstly I get a segmentation error during initialization. To avoid that I do initialization without the udf and while running it I reattach it. I know it is not a brilliant way but just want to see it working. Secondly, my outlet pressure and the mass flow rate always remains zero. I tried implementing lot of modifications on it but all seems to fail. Can you kindly help me with this.
#include "udf.h"
DEFINE_INIT(my_init_func)
Domain *domain = Get_Domain(1);
Thread *thread = Lookup_Thread(domain,11);
face_t f;
begin_f_loop(f, thread)
F_UDMI(f,thread,0) = 0;
end_f_loop(f, thread)
printf("Step Pressure Initialized!");
DEFINE_PROFILE(transient_pressure, thread, position)
real Res = 7.0e+08; /* Resistance m^-4 s^-1 kg^1 */
face_t f;
float flow, pout, pprev;
real dens = 1050; /* kg m^-3 */
flow = F_FLUX(f,thread)/dens;
pout = Res*flow;
F_PROFILE(f, thread, position) = pout;
DEFINE_EXECUTE_AT_END(pressure_save)
face_t f;
F_UDMI(f,thread,0) = F_P(f,thread);
printf("Step Pressure Recorded!");
shiju7279 is offline   Reply With Quote
Old   October 26, 2017, 22:11
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
#include "udf.h"
face_t f;
face_t f;
pout = Res*flow;
face_t f;
Hello
you may try to use this code for initialization part:
Thread *t;
face_t f;
Domain *d;
d = Get_Domain(1);
t = Lookup_Thread(domain,11);
thread_loop_f(t, domain)
begin_f_loop(f,t)
end_f_loop(f, t)
Also I'm suggesting you to add UDMs to control your profile input, for instance add F_UDMI(f,thread,1) = pout; before F_PROFILE(f, thread, position) = pout;
In this way you may see your input data using contours.
Best regards
AlexanderZ is offline   Reply With Quote
UDF to adjust pressure outlet a.lynchy FLUENT 4 February 15, 2021 01:50
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Help ME For Pressure Outlet UDF PLZ!!! Yapoo Fluent UDF and Scheme Programming 2 December 26, 2011 12:45
pressure inlet & outlet. help ASAP Plz engahmed Main CFD Forum 0 June 13, 2010 16:34
Fluent 5.2, UDF and Pressure BC's Alfonso Ferrandez FLUENT 0 May 4, 2000 08:02
