UDS transport in a curved channel
Old   October 17, 2017, 15:32
Default UDS transport in a curved channel
ali
alinik is on a distinguished road
Hi all,
I have noticed that the same transport equation for a UDS would result in totally different distributions of that scalar inside the domain if one is curved and the other case is rectangular.
Of course for the curved channel it was rewritten for curvilinear coordinate system. So that would not be the reason.
I was wondering if anyone had similar experiences and how it could be fixed?
In this picture you can see the distribution. Please note the amount of drop is no longer the same.
alinik is offline   Reply With Quote
Old   October 17, 2017, 21:38
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Hello.
I'm confused, did you put cylindrical material properties for UDS Diffusivity for curved case?
Best regards
AlexanderZ is offline   Reply With Quote
Old   October 17, 2017, 21:40
ali
in terms of diffusivity it would not matter since it is a constant and is coordinate invariant. I re-wrote the source term for curvilinear system and it would not produce the same distribution as rectangular case.
Thanks,
Old   October 17, 2017, 23:17
Alexander
As a first step I'm suggesting you to try to use cylindrical properties for diffusivity and use constant values for all directions.
(so you will put radial = tangential = normal = *some_constant_value*)
In my case I had uniform source, that's why I can't make you advice on that
Best regards
Old   October 18, 2017, 13:22
ali
Thanks but the problem is not the diffusivity since it is isotropic.
My problem is with source term. Do you know how we can use coordinate systems other than cartesian?
Old   October 18, 2017, 22:42
Alexander
Unfortunately, I do not know the way how to use other coordinate system.
If you find the way, please share
Best regards
Gradient of field obtained thro' UDS transport eqn is discontinuous at interfaces jyothsna k ANSYS 0 January 12, 2016 08:00
Solver for Curved Channel mohammad81 OpenFOAM Running, Solving & CFD 7 June 1, 2014 15:38
Curved Channel christianfrias OpenFOAM Running, Solving & CFD 0 December 24, 2009 00:52
UDS - Modification of the transport equation Jo FLUENT 0 April 3, 2007 12:46
UDS transport: strange results Ale FLUENT 1 November 6, 2003 07:28
