Help with UDF for a cardiac pulse
Old   October 5, 2017, 06:27
Default Help with UDF for a cardiac pulse
Mohammed Ameenuddin
ch@resch is on a distinguished road
I want to model a pulsatile blood flow in an artery using FLUENT. I have written UDF for fully developed flow and pulsatile flow like a sine wave. But I do not know how to implement a physiological velocity profile (as attached) in my simulations using UDF.
I would appreciate any help provided as this will be useful for my research.
Thanks and Regards
ch@resch is offline   Reply With Quote
Old   June 29, 2018, 04:57
Sadia Khan
Sadia Khan is on a distinguished road
Did you get this udf?
i need it tooo
Sadia Khan is offline   Reply With Quote
Old   July 2, 2018, 16:14
zobekenobe
zobekenobe is on a distinguished road
I will send or cite a paper sometime, where the authors modeled a similar pulsatile flow with an equation and that equation was used to define the velocity.
You can also model the trend using the Fourier Transform or Wavelets and then read in the data in the UDF and set the velocity
zobekenobe is offline   Reply With Quote
Old   August 16, 2018, 02:21
Mohammed Ameenuddin
Thanks that would be really helpful if you could share them.
arter, pulsatile flow
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
udf for multiple reaction alihosseini63 Fluent UDF and Scheme Programming 0 July 4, 2013 19:37
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
