October 2, 2017, 11:44 |
Warning message C4133 while compiling
Stefan Holl
Hi!
I've got the following udf code for a udrgm #include "udf.h" #include "stdio.h" #include "ctype.h" #include "stdarg.h" #define MW 28.966 /* molec. wt. for single gas (kg/kmol) */ #define rgas (UNIVERSAL_GAS_CONSTANT/MW) #define b 0.001265 /* covolume term for single gas (m^3/kg) */ /* b = R * T_crit / ( 8 * p_crit ) */ #define CC1_cold 1048.71 #define CC2_cold -0.383871 #define CC3_cold 0.945559e-3 #define CC4_cold -0.548647e-6 #define CC5_cold 0.0790677e-9 #define CC1_hot 873.949 #define CC2_hot 0.384069 #define CC3_hot -0.140147e-3 #define CC4_hot 0.0245553e-6 #define CC5_hot -1.63649e-12 /* Reference State: */ #define P_DAT 101325.0 /*Referencepressure*/ #define T_DAT 288.15 /*Referencetemp*/ static int (*usersMessage)(char *,...); static void (*usersError)(char *,...); static double cp_datum_ref; /************************************************** *******************/ /* Thermodynamic functions: */ /************************************************** *******************/ /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_error */ /*--------------------------------------------------------------------*/ DEFINE_ON_DEMAND(I_do_nothing) { /* this is a dummy function to allow us */ /* to use the compiled UDFs utility */ } void ANEOS_error(int err, char *f, char *msg) { if (err) usersError("ANEOS_error (%d) from function: %s\n%s\n",err,f,msg); } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_Setup */ /* Compute some constants */ /*--------------------------------------------------------------------*/ void ANEOS_setup(Domain *domain, cxboolean vapor_phase, char *filename, int (*messagefunc)(char *format, ...), void (*errorfunc)(char *format, ...)) { cp_datum_ref = CC1_cold*log(T_DAT) + T_DAT*(CC2_cold + T_DAT*(0.5*CC3_cold+ T_DAT*(0.333333*CC4_cold + 0.25*CC5_cold*T_DAT))); usersMessage = messagefunc; usersError = errorfunc; usersMessage("\nLoading Real-Ideal Library: %s\n", filename); } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_density */ /* Returns density given T and press */ /*--------------------------------------------------------------------*/ double ANEOS_density(cxboolean vapor_phase, double Temp, double press, double yi[]) { double rho = 1. / ( (rgas*Temp/press) + b ); return rho; /* (kg/m^3) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_H_ideal_gas */ /* Returns ideal gas specific enthalpy for a given T */ /*--------------------------------------------------------------------*/ double ANEOS_H_ideal_gas(double Temp) { double Ho = 0.0; if (Temp<=1000) Ho = Temp*(CC1_cold + Temp*(0.5*CC2_cold + Temp*(0.333333*CC3_cold+ Temp*(0.25*CC4_cold + Temp*0.2*CC5_cold)))); if (Temp>1000) Ho = Temp*(CC1_hot + Temp*(0.5*CC2_hot+ Temp*(0.333333*CC3_hot + Temp*(0.25*CC4_hot + Temp*0.2*CC5_hot)))); return Ho; } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_cp_ideal */ /* Returns specific heat at a given T, assuming ideal gas */ /*--------------------------------------------------------------------*/ double ANEOS_cp_ideal(double Temp) { double cpo = 0.0; if (Temp<=1000) cpo = CC1_cold + Temp*(CC2_cold + Temp*(CC3_cold + Temp*(CC4_cold + Temp * CC5_cold))); if (Temp>1000) cpo = CC1_hot + Temp*(CC2_hot + Temp*(CC3_hot + Temp*(CC4_hot + Temp * CC5_hot))); return cpo; /* (J/kg-K) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_specific_heat */ /* Returns specific heat at a given T */ /*--------------------------------------------------------------------*/ double ANEOS_specific_heat(double Temp, double rho, double P, double yi[]) { double cp, ANEOS_cp_ideal(Temp); cp = ANEOS_cp_ideal(Temp); return cp; /* (J/Kg-K) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_enthalpy */ /* Returns specific enthalpy given T and rho */ /*--------------------------------------------------------------------*/ double ANEOS_enthalpy(double Temp, double rho, double P, double yi[]) { double delta_h,press,v,h, ANEOS_H_ideal_gas(Temp); v = 1.0 / rho; press = rgas * Temp / (v - b); delta_h = press*b; h = ANEOS_H_ideal_gas(Temp)+delta_h; return h; /* (J/Kg) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_entropy */ /* Returns entropy given T and rho */ /*--------------------------------------------------------------------*/ ANEOS_entropy(double Temp, double rho, double P, double yi[]) { double delta_s,v,vo,s; double cp_integral = 0.0; if (Temp<=1000) cp_integral = CC1_cold*log(Temp) + Temp*(CC2_cold + Temp*(0.5*CC3_cold+ Temp*(0.333333*CC4_cold + 0.25*CC5_cold*Temp)))- cp_datum_ref; if (Temp>1000) cp_integral = CC1_hot*log(Temp) + Temp*(CC2_hot + Temp*(0.5*CC3_hot+ Temp*(0.333333*CC4_hot + 0.25*CC5_hot*Temp)))- cp_datum_ref; v = 1.0 / rho; vo = rgas*Temp/P_DAT; delta_s = rgas*log((v-b)/vo); s = delta_s + cp_integral; /* (J/kg) */ return s; } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_mw */ /* Returns molecular weight */ /*--------------------------------------------------------------------*/ double ANEOS_mw(double yi[]) { return MW; /* (Kg/Kmol) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_speed_of_sound */ /* Returns s.o.s given T and rho */ /*--------------------------------------------------------------------*/ double ANEOS_speed_of_sound(double Temp, double rho, double P, double yi[]) { double cp = ANEOS_specific_heat(Temp, rho, P, yi); double v = 1./rho; double c = (v/(v-b))*sqrt(cp*rgas*Temp/(cp-rgas)); return c; /* (m/s) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_viscosity */ /* Viscosity via 3-coefficient Sutherland Law */ /*--------------------------------------------------------------------*/ double ANEOS_viscosity(double Temp, double rho, double P, double yi[]) { double mu = 0.0; double mu_Sutherland = 1.7894e-05; double T_Sutherland = 273.11; double S_Sutherland = 110.56; mu = mu_Sutherland * ( pow( (Temp/T_Sutherland),1.5) ) * (T_Sutherland + S_Sutherland) / (Temp + S_Sutherland); return mu; /* (Kg/m-s) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_thermal_conductivity */ /* Euckun formula */ /*--------------------------------------------------------------------*/ double ANEOS_thermal_conductivity(double Temp, double rho, double P, double yi[]) { double cp,mu,k; cp = ANEOS_specific_heat(Temp, rho, P, yi); mu = ANEOS_viscosity(Temp, rho, P, yi); k = (cp+1.25*rgas)*mu; return k; /* (W/m-K) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_rho_t */ /* Returns derivative of rho wrt. T at constant p */ /*--------------------------------------------------------------------*/ double ANEOS_rho_t(double Temp, double rho, double P, double yi[]) { double press,v,rho_t; v = 1.0 / rho; press = rgas*Temp/(v - b); rho_t = -rgas/(press*v*v); return rho_t; /* (Kg/m^3-K) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_rho_p */ /* Returns derivative of rho wrt. p at constant T */ /*--------------------------------------------------------------------*/ double ANEOS_rho_p(double Temp, double rho, double P, double yi[]) { double press,v,rho_p; v = 1.0 / rho; press = rgas*Temp/(v - b); rho_p = rgas*Temp/(press*press*v*v); return rho_p; /* (Kg/m^3-Pa) */ } /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_enthalpy_t */ /* Returns derivative of h wrt. T at constant p, which */ /* equals cp */ /*--------------------------------------------------------------------*/ double ANEOS_enthalpy_t(double Temp, double rho, double P, double yi[]) { double cp; cp = ANEOS_specific_heat(Temp, rho, P, yi); return cp; /*--------------------------------------------------------------------*/ /* FUNCTION: ANEOS_enthalpy_p */ /* returns derivative of h wrt. p at constant T; */ /*--------------------------------------------------------------------*/ } double ANEOS_enthalpy_p(double Temp, double rho, double P, double yi[]) { return b; } /************************************************** ********************/ /* Actual UDF hook (macro) into the User Defined Real Gas Model: */ /************************************************** ********************/ /*--------------------------------------------------------------------*/ /* Export real gas functions to the solver: */ /*--------------------------------------------------------------------*/ UDF_EXPORT RGAS_Functions RealGasFunctionList= { ANEOS_setup, /* initialize */ ANEOS_density, /* density */ ANEOS_enthalpy, /* enthalpy */ ANEOS_entropy, /* entropy */ ANEOS_specific_heat, /* specific_heat */ ANEOS_mw, /* molecular_weight */ ANEOS_speed_of_sound, /* speed_of_sound */ ANEOS_viscosity, /* viscosity */ ANEOS_thermal_conductivity, /* thermal_conductivity */ ANEOS_rho_t, /* drho/dT |const p */ ANEOS_rho_p, /* drho/dp |const T */ ANEOS_enthalpy_t, /* dh/dT |const p */ ANEOS_enthalpy_p, /* dh/dp |const T */ }; Does anybody know, how I can get rid of the warning message: warning C4133: "Initialization": Incompatible types - from "int (*)(double,double,double,double *)" to "double (*)(double,double,double,double *)" ?? Thanks in advance! |
udf - warning c4133 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
1.5-dev GCC-4.5.1 | linnemann | OpenFOAM | 22 | November 3, 2010 03:09 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
