UDF for density variaiton
Old   September 28, 2017, 04:36
Post UDF for density variaiton
Arslan Saleem
asaleem89 is on a distinguished road
I'm trying to model air-vapor mixture using the species transport model. The flow is incompressible, but the density variation due to temperature or humidity is taken into consideration using the expression given below:
rho=p/(RT(m/M))
where, m is the mass fraction of species and M is the molecular weight of the species
I have written a UDF but on interpretation, it's giving a "structure implementation error". Here is the UDF:
#include "udf.h"
DEFINE_PROPERTY(cell_density, c, t)
real sum=0; int i;
Material *sp;
real rho;
real m=18.01534;
real R= UNIVERSAL_GAS_CONSTANT/m;
Property *prop;
mixture_species_loop(THREAD_MATERIAL(t),sp,i)
prop= (MATERIAL_PROPERTY(sp));
rho= generic_property(c,t,prop,PROP_rho,C_T(c,t),C_P(c, t));
sum += C_P(c,t)/(R*C_T(c,t)*(C_YI(c,t,i)/m));
return sum;
asaleem89 is offline   Reply With Quote
density variation, fluent, species transport, udf
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
