Thermoelectric UDF running problem. Error 193
Old   September 27, 2017, 09:56
Exclamation Thermoelectric UDF running problem. Error 193
Pablo Mtz. Filgueira
pablo_fil is on a distinguished road
Hello everyone.
I'm trying to run a simulation where an UDF is involved and I can't make it run.
I attach the files in this LINK
It includes the .cas file and a library .dll.
They come from a paper https://doi.org/10.1016/j.ijheatmass...er.2010.08.024 where a thermoelectric UDF is developed within ANSYS Fluent. In the appendix says that it contains the required files to work in Fluent 12 directly.
I create my case and place the library in C:\Users\pxxxxxxxx\Documents\TEG\libudf\win64\3d , which I think is the right place. I have also tried with no success placing it into the root of the case.
I've been prompted in this error every time I start this simulation.
Opening library "C:\Users\pxxxxxxxx\Documents\TEG\libudf"...
Error: Error code: 193
Error: Error code: 193\n
Error Object: #f
I've been reading many posts here Post1 Post2 Post3 ... and no solution given there solves my problem.
I would like, first of all, someone to test that file to know if it works. It is cool stuff so I think you will enjoy trying it
I'm running on Visual Studio Express 2015 and launch Fluent from VS2015 x86 x64 Cross Tools Command Prompt. I can run and build all the tutorials so I think my compilation environment is OK. My PC is Windows 10 Pro 64bits. My Fluent version is 17.1.
Any suggestion or test will be welcomed.
Thank you.
Edit:
I solved it, 32 bits system was the key.
pablo_fil is offline   Reply With Quote
Old   March 9, 2018, 10:36
Inderjeet Singh
Inderjeet Singh is on a distinguished road
Originally Posted by pablo_fil View Post
Hello everyone.
Error Object: #f
Thank you.
Can you please explain how did you overcome that problem.. ? I have similar error ... In the end you mentioned "32 bit system was the key". Did you converted it or something else ?
Inderjeet Singh is offline   Reply With Quote
Old   March 15, 2018, 04:59
Nope, I found a 32 bit version and installed it over a virtual machine.
193, error, fluent, thermoelectric, udf
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem running fluent with udf on supercomputer(batch system) Sept24 Fluent UDF and Scheme Programming 3 October 15, 2015 13:50
Wankel Engine UDF Problem Kxt908 Fluent UDF and Scheme Programming 0 February 2, 2014 09:15
UDF Problem about Grid Motion !!! Zhengyu Gao Fluent UDF and Scheme Programming 0 December 6, 2013 20:45
Mesh UDF problem kornetka Fluent UDF and Scheme Programming 4 July 25, 2013 07:54
