Volume flow rate and assinged pressure on a BC
Old   September 16, 2017, 11:57
Default Volume flow rate and assinged pressure on a BC
Tarantino
Tarantino is on a distinguished road
Hello all!
In a UDF, I need to return the volume flow rate on a pressure outlet boundary. How can I do so? Is there any macro for this?
In addition, I want to return the pressure outlet which was assigned to that boundary.
I want to know how this can be done? Is there any macro for this?
Thanks.
Tarantino is offline   Reply With Quote
Old   September 17, 2017, 22:24
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Originally Posted by Tarantino View Post
Hello all!
Thanks.
Hello
Answers to these questions can be found in fluent tutorials. See ANSYS Fluent Tutorial Guide
However,
monitor for volume flow rate:
In fluent GUI go to solution -> Monitors -> Surface Monitors -> create ->
you may plot (to window) and/or write (to file) on each iterations (for stedy-state) or each timestep (transient) -> under Report Type choose Volume flow rate -> select outflow under Surfaces list -> OK
monitors for pressure:
all the same, but under Report Type choose Area-Weight Average-> Field Variable is Pressure -> Static Pressure -> select outflow under Surfaces list -> OK
Read manual
Best regards
AlexanderZ is offline   Reply With Quote
Old   September 18, 2017, 02:32
Tarantino
Hi AlexanderZ,
I think you didn't read my question or you misunderstood!
I want to return volume flow rate and assigned pressure on a pressure outlet boundary in a UDF not in TUI!!
Old   September 19, 2017, 00:57
Alexander
Hello
I missed your point about UDF.
Read ANSYS Fluent Customization Manual
3.2.4.4. Flow Variable Macros at Interior and Boundary Faces
F_P(f,t) built in macros for Pressure on boundary
F_FLUX(f,t) built in macros for mass flow rate on boundary
Try to search tutorials with these functions
Best regards
