how to write udf for a component source term on a wall ?
Like Tree9Likes
Old   November 13, 2019, 04:33
Vignesh Lakshmanan
ViLaks is on a distinguished road
Originally Posted by Hasan_Najafi View Post
Dear Vignesh,
The “dS[eqn]=0;” is derivative of the source term with respect to the temperature (for the energy source term in your UDF). This line can enhance the stability of the solution and help convergence rates due to the increase in diagonal terms on the solution matrix. For more information about it, you can see the ANSYS FLUENT UDF Manual (there is an example for the source term that you can understand the argument's type of this Macro easily).
To make the correlation between the temperature and position of “x”; if your temperature changes as a function of position, you can write your source term by using these lines.
real x[ND_ND], xx, yy, zz;
C_CENTROID(x,c,t);
xx=x[0]; //x-position
yy=x[1]; //y-position
zz=x[2]; //z-position
Best regard
Hasan Najafi Khaboshan
Dear Hasan,
Thanks for your swift reply. Sorry, I confused you. By "x", I didnt mean position. Its difficult to explain in words. But I understood the part and I will try to workout the problem.
Regards
Vignesh
ViLaks is offline   Reply With Quote
Old   October 8, 2021, 07:34
Default Wall Surface Reactions
  #22
Ugur Goktolga
mugurg is on a distinguished road
I think the problem in the original question could've been solved without any UDF. In Fluent, you can also specify wall surface reactions, and then define your reaction rate constants. By playing with the reaction rate constants (Pre-exponential term, activation energy and temperature exponent), you can get your desired reaction rates I believe.
mugurg is offline   Reply With Quote
Old   January 17, 2022, 11:34
Joe
CFD27 is on a distinguished road
Hi all,
I would like to implement a source in the cell row that is adjacent to a wall and
I think the UDF of Hasan_Najafi is a good approach for this.
I have already compiled the UDF without error, but I cannot execute the UDF on demand in Fluent, because Fluent does not respond when I want to execute the UDF in the "Execute on Demand" dialog box.
Any suggestion would be helpful.
Many greetings
Joe
CFD27 is offline   Reply With Quote
Old   January 19, 2022, 04:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
can you execute on_demand macro in case there is only Message("text"); function inside?
#include "udf.h"
DEFINE_ON_DEMAND(test)
Message("text");
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 19, 2022, 04:29
Joe
Dear Alexander,
Thank you for your reply. As in the UDF of Hasan_Najafi I used the UDM to mark the cells adjacent to the wall.
In the meantime, I checked if the UDF saves the values of the UDM to the cells on the wall.
This is the case. Now I have the question, what can be the reason, that nevertheless the source is not implemented.
The code looks like the following:
#include "udf.h"
DEFINE_ON_DEMAND(selecting_cell)
#if !RP_HOST
Domain *d;
Thread *t, *tc, *t0;
face_t f;
cell_t c, c0;
d = Get_Domain(1);
tc = Lookup_Thread(d, 8);
thread_loop_c(t, d)
begin_c_loop(c, t)
C_UDMI(c, t, 0) = 0;
end_c_loop(c,t)
begin_f_loop(f, tc)
c0 = F_C0(f, tc);
t0 = THREAD_T0(tc);
C_UDMI(c0, t0, 0) = 1;
end_f_loop(f,tc)
#endif
DEFINE_SOURCE(energy_source, c, t, dS, eqn)
real source;
if (C_UDMI(c, t, 0) > 0)
source = 1000.0;
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
Thank you in advance.
Many greetings
Joe
Old   January 19, 2022, 04:41
Alexander
check values of udm_0 in your domain, it must be 1 near the wall with ID = 8
best regards
Old   January 19, 2022, 04:58
Joe
Dear Alexander,
I checked the values of the UDM in the cells adjacent to the wall and instead of 1, they are 0.5. Shouldn't this work with 0.5?
Thanks
Many greetings
Joe
Hasan_Najafi likes this.
Old   January 20, 2022, 00:42
Alexander
its not possible to have 0.5 as you have only 0 or 1 in your code.
this is error of plotting:
turn off node values while making the contour.
however, as you can see something except 0, means udf works, so source is applied also.
1000 means 1000W/m3. check if it enough to get some effect for your case
CFD27 likes this.
best regards
Old   January 20, 2022, 07:07
Joe
Dear Alexander,
Thank you for your answer. I have issued the node values and am now getting values of 1.
Additionally, I have separated the UDF's.
Both UDF' I have compiled with no errors.
The DEFINE_SOURCE UDF I have hooked in the desired fluid domain and the DEFINE_ON_DEMAND UDF I have executed on demand.
Now the source UDF works as well.
But the question arises why not both UDF could be executed on demand.
Shouldn't this also work?
Many thanks in advance.
Many greetings
Joe
Old   January 20, 2022, 22:03
Alexander
On_demand and define_source are two separated functions predefined in fluent structure. It's not possible to execute one fluent function from another.
On_demand is eceuted manually by user from fluent GUI
define_source returns some value to specified zone, is executed before each time step automatically
Hasan_Najafi and CFD27 like this.
best regards
Old   January 21, 2022, 03:10
Joe
Thank you for your reply. I had assumed that both are executed together. Then I found the problem. Thank you for your help.
Many greetings
Joe
Old   February 13, 2022, 17:28
DhyaniBaba
pdhyani96 is on a distinguished road
Dear Vignesh,
I think the below UDF will help you.
First, you should mark your appropriate cells near the boundary condition by defining the UDM as DEFINE_ON_DEMAND Macro. Then, you can use it as an “if” statements in your source term. It should be noted that this UDF must be compiled and will be just run in parallel cases. I hope this UDF could help you.
Best regard
#include "udf.h"
DEFINE_ON_DEMAND(selecting_the_cells)
	#if !RP_HOST
		Domain *d;
		face_t f;
		cell_t c, c0;
		d=Get_Domain(1);
		tc=Lookup_Thread(d,9); //thread pointer of the surface (the ID can be obtained from the boundary condition panel)
		//Loop through all the cell threads in the domain
		thread_loop_c(t,d)
			//Loop through the cells in each cell thread
			begin_c_loop(c,t)
				C_UDMI(c,t,0)=0;
			end_c_loop(c,t)
		begin_f_loop(f,tc)
			c0=F_C0(f,tc);
			t0=THREAD_T0(tc);
			C_UDMI(c0,t0,0)=1;
		end_f_loop(f,tc)
	#endif
	real source;
	if (C_UDMI(c,t,0)>0.)
		source=1000.;
		dS[eqn]=0.;
	else
		source=0.;
		dS[eqn]=0.;
	return source;
I am doing a similar problem, where I apply a mass flow source term at an inlet boundary. I came across your UDF, although I am a bit confused on how to implement it? After I interpret the code, I see two UDFs loaded in Fluent, one is for selecting_the_cells, and the other is energy_source. How do I apply these UDFs, and where?
Secondly, I am just starting to work with UDFs, so I am having trouble understanding the syntax, and following the manual is not trivial for me as of now. Could you please shed some light on the syntax?
Thanks,
Priyank
pdhyani96 is offline   Reply With Quote
Old   February 15, 2022, 23:24
Hasan_Najafi is on a distinguished road
Thanks,
Priyank
Hi. This UDF code has been generated for parallel processing. So, you should launch with a parallel solver. You should compile the UDF. I give you some steps below to compile this UDF.
1. Set the ID number (in Line 11) of your inlet boundary in the UDF and save it with a filename.c.
2. Launch with a parallel solver.
3. Set one User-defined memory in your case (User Define>Memory>set 1 for Number of User-Defined Memory Location).
4. Compile the UDF.
5. Set the UDF of your source term in Cell Zone conditions.
6. Initialize your case. I think if you hook the Execute on Demand and after that Initialize your case, the data of UDM will be gone.
7. Hook Execute on Demand (User Define>Execute on Demand button>chose the name of Execute on Demand UDF "selecting_the_cells">click OK). Also, you can plot the contour of UDM before running your case to check.
8. Then you can run your solver.
Let me know if you need more help.
Hope you run your case file.
Best regards,
Hasan_Najafi is offline   Reply With Quote
Old   April 29, 2022, 03:08
București
alexandraene is on a distinguished road
Hello! I kind of face the same issue here. I have used the same code in which I have added the "Message("%e\n", C_UDMI(c0,t0,0))" in order to check if the values for the cells 0 and 1 are implemented. After I compile and run the Define_On Demand macro I receive a message with the numbers of cells with 0 and 1. Nonetheless, the source term is implemented as 0 everywhere. I checked the UDM contour and it seems that all cell values are 0. Could you please be so kind and give me an idea on what I am doing wrong? This will be highly appreciated!
alexandraene is offline   Reply With Quote
Old   May 1, 2022, 01:26
Hi, it would be better to check the UDM by plotting the contour. Note that, turn off node values while making the contour.
You should set the UDM, then interpret the Define_On Demand and check the contour.
mass source udf, wall udf
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
