September 6, 2017, 21:01 |
UDF controlled dynamic mesh problem
joson
Hello, everyone!
I am doing a simulation of 2D VIV of circular cylinder. The cylinder is supposed to oscillate in the cross-stream direction with amplitude around 1D (diameter D=0.01m). However, the amplitude in my simulation behaves very small (less than 0.0001m). The validation of mesh and solver has been checked by the fixed cylinder simulation. The basic parameters and settings are listed below: inlet velocity:0.02m/s dynamic mesh: diffusion smoothing+remeshing diffusion smoothing:boundary distance:0.5 remeshing: local cell the udf file is attached below. As the image shown, some layers of mesh near the cylinder are set moving with the boundary. During the simulation, the motion of the cylinder seems "suppressed" by something. I tried to reduce the mass ratio, it does not work too, even when the mass ratio is small the simulation will be divergent. I am wondering if anyone has similar experience can give me some suggestions? Thanks very much!! Regards, Jian |
dynamic mesh, fluent - udf |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Dynamic mesh problem | entlit | FLUENT | 0 | June 9, 2016 05:19 |
UDF dynamic mesh problem | gaozhengyu | Fluent UDF and Scheme Programming | 1 | December 27, 2012 02:18 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Problem related with UDF for dynamic mesh | Ryan | FLUENT | 1 | April 16, 2004 07:05 |
