access the adjacent cells of a node
Old   September 1, 2017, 14:13
Lightbulb access the adjacent cells of a node
mach_25
mach_25 is on a distinguished road
Hi
Does anybody know how I can access the adjacent cells of a node in udf ? is there any macro or instruction for this purpose?
my project contains dynamic mesh. i wanna investigate the effects of erosive burning in solid fuel rocket. for this purpose i need (du/dy) near the burning area.(u is the velocity of flow in the direction of x). and (du/dy) determines the burning rate amount(r) according to errosive burning. then burning rate(r) determines how nodes of fuel boundary retreats(x=r * t). t is time step. type of moving boundary(fuel boundary) is user-defined. and my project is 2-D.
as you know i should work with nodes in moving boundary(fuel boundary) in dynamic mesh and according to my description i wanna access the adjacent cells of moving boundary(fuel boundary) nodes.
thanks for any help
this is the picture of this project. an hypothetical 2-D solid fuel rocket:
mach_25 is offline   Reply With Quote
adjacent cell of node, dynamic mesh, node, udf, user-defined bc
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Fast Search adjacent cells in an unstructured grid andreyh Mesh Generation & Pre-Processing 0 November 1, 2015 18:40
[blockMesh] Adjacent cells are disjunct after blockMesh run NablaDyn OpenFOAM Meshing & Mesh Conversion 1 October 28, 2015 08:15
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 12:57
