Can we write UDF for secondary phase droplet/bubble diameter in Eulerain model? |
August 29, 2017, 15:10 |
Navier Stoke
I am running Eulerain-Eulerian multi-phase simulation with air (primary) and water (secondary) phase. I have studied UDF manual. We can write UDF only for granualar diameter while using Eulerian model. Is this the case? Or we can write for droplet/bubble as well? I have written UDF for droplet diameter(water) which gives segmentation error when I use Eulerain Model but when I use Mixture Model, UDF works fine. What are the possible errors? |
September 7, 2017, 16:02 |
volume fraction
Rep Power: 9 |
dear friend,
im working on the similar topic can you lease share your UDF. i want to know how you acess to the different phase, I need the volume fraction of the different phase at each cell |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 21:21 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 07:12 |
UDF for discrete phase model | simo11 | FLUENT | 0 | June 9, 2011 07:15 |
UDF for the mixture model | khar nab | FLUENT | 0 | July 31, 2008 07:29 |
UDF for bubble diameter in two phases, help!! | edgar h | FLUENT | 0 | June 19, 2008 21:37 |
