Receiving errors while building UDF, but it loads just fine
Old   August 29, 2017, 13:18
Default Receiving errors while building UDF, but it loads just fine
ali
alinik is on a distinguished road
Hi all,
I receive numerous errors when I compile and build my UDF codes but I have no problem loading them and using them.
Some of the errors are:
error: Domain undeclared (first use in this function)
error: (Each undeclared identifier is reported only once
error: for each function it appears in.)
Why is that?
Thanks,
Ali
alinik is offline   Reply With Quote
Old   August 30, 2017, 06:13
pakk will become famous soon enough
The error "Domain undeclared" means that you use the variable "Domain", but you did not declare this variable. Without seeing your code, I can not give more detailed information.
And when you load and use the udf anyway, you will get results for the most recent udf code that worked. So the code that you wrote, and the code that Fluent uses, will not be the same. Avoid this!
pakk is offline   Reply With Quote
Old   August 30, 2017, 14:41
ali
Understood,
Thank you so much Pakk
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Errors in melting of ice-particles in ice-slurry flow UDF devshi Fluent UDF and Scheme Programming 3 November 28, 2016 13:45
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
