Error: UDf-scheme connectivity
Old   August 24, 2017, 10:07
Default Error: UDf-scheme connectivity
Cees Haringa
CeesH is on a distinguished road
Hi all,
I started building a GUI for my collection of UDFs, but I'm running into trouble.
I designed the scheme file pretty much analogous to the example in the fluent manual, and that part seems to work. However, when I click OK to start the execute_from_GUI UDF, it gives me an error (UDF was properly compiled).
The error is: ERROR: rpgetvar: MetaUDF/SWITCH_WritePartData: undefined variable.
It seems the following line (and all similar lines after that) isn't working
if(RP_Get_Boolean("MetaUDF/SWITCH_WritePartData"))
However, the variable has been properly defined in the scheme file. Am I overlooking something to connect the two?
CeesH is offline   Reply With Quote
Old   August 25, 2017, 00:53
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Try using only lowercase letters for variables both in scheme file and UDF.
MetaUDF/SWITCH_WritePartData -> metaudf/switch_writepartdata
Hope it will help.
Best regards,
Zorin Alexander
AlexanderZ is offline   Reply With Quote
Old   August 25, 2017, 04:03
Cees Haringa
It's solved, however the solution was... different.
Apperantly, the issue was not in the rp-variable. the parameter was still included as a definition macro, from previous versions. Of course trying to assign an rp-variable to a macro didn't work out too well.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
can you tell me best gradient, pressure & momentum order selection in fluent sanjiiv FLUENT 6 February 14, 2020 07:07
Scheme - UDF connectivity: RPgetvar not working CeesH Fluent Multiphase 0 August 24, 2017 08:10
Suitable scheme for node connectivity Simbelmynė Main CFD Forum 1 March 25, 2015 12:01
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
