FLUENT 18.0/Windows server 2012 - compilation without crossx64 cmd window |
August 9, 2017, 06:09 |
Cees Haringa
Hello all,
I am currently running FLUENT 18.0 on a windows server 2012 computer. After some trial and error, I managed to get compilation of UDFs up and running, but only when opening fluent via the x64 cross command tool of visual studio. On previous computers, I had no problem compiling in FLUENT when opened regularly. These previous systems I used were FLUENT 15.7 - windows 7, windows 8 and 8.1, and FLUENT 17.0 - windows 10. However, on the current system I just can't manage to get the job done. I am running the following combination: FLUENT 18.0 Windows server 2012 Visual Studio Express 2013 (12.0) Microsoft SDK 8.0 .NET 4.5.1 In order to get things up and running, I set LIB, INCLUDE and path variables (Windows Environment variables- to solve problems in compiling UDF in Fluent), but as mentioned before things only work when starting via the x64 cross tool, whereas on my previous systems this was not required. Any tips/tricks/ideas to solve this? Best regards Cees |
May 27, 2019, 12:58 |
Rep Power: 8 |
Hi, I have defined a udf for polymer additives has this problem on compiling. firstly It was working well but now it is showing me rhis error again and again. I do not know why it comes out even I did not change anything in my udf and it is creating an error on hooking my file of udf. can anyone please share the solution? I am not very good at udf solving. Thanks!
c:\users\tayyaba\desktop\new folder\libudf\src\1.c(84) : warning C4700: uninitialized local variable 'fxp' used c:\users\tayyaba\desktop\new folder\libudf\src\1.c(85) : warning C4700: uninitialized local variable 'fyp' used c:\users\tayyaba\desktop\new folder\libudf\src\1.c(87) : warning C4700: uninitialized local variable 'fxs' used c:\users\tayyaba\desktop\new folder\libudf\src\1.c(88) : warning C4700: uninitialized local variable 'fys' used # Generating udf_names.c because of makefile 1.obj |
May 27, 2019, 23:22 |
#3 | |
Alexander
Rep Power: 34 |
best regards |
Fluent on windows server | Shamoon Jamshed | ANSYS | 0 | November 15, 2009 13:52 |
Fluent on windows server | Shamoon Jamshed | FLUENT | 0 | November 14, 2009 13:32 |
Installing Fluent on Server | CAM | FLUENT | 0 | January 12, 2007 21:20 |
Simple question to Window XP Fluent user | Aireen | FLUENT | 3 | August 22, 2005 11:36 |
window fluen and linxu fluent | ztdep | FLUENT | 0 | July 4, 2005 09:44 |
