Pls help me with the scattering phase function UDF
Old   August 2, 2017, 00:22
Default Pls help me with the scattering phase function UDF
cszssj
cszssj is on a distinguished road
Here is a simple two dimensional case, the DO model is uesd, the inlet and outlet boundary is semitransparent. A source term is added to the solid phase (3e7 W/m3) .
When i use the default isotropic scattering phase function, the sum of radiation flux on the boundaries is equal to the integral of source term(3.6e5 W),which is right. But when i use the UDF( copied from the user manual), the sum of radiation flux changes , which is wrong. Even I use the "ScatIso" UDF, which basically is isotropic scattering phase function, the answer still changes.
So please help me to solve this problem, thanks advance.
https://drive.google.com/file/d/0B-G...ew?usp=sharing
cszssj is offline   Reply With Quote
udf
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
asymmetry factor (C1/3) Scattering phase function Ahmed Main CFD Forum 1 September 24, 2003 05:31
