July 19, 2017, 12:05 |
Fluent/icepak UDF for heat pipe simulation
jiayu hu
Rep Power: 17 |
I want do some works for heat pipe simulation during transit time, First I ‘ll construct a rod as heat pipe and then give the thermal conductive such as 10000W/m.K, I want to detect the cross section’s heat flux during the transit time ,if it great than some values I’ll change the rod’s thermal conductive. All the process can be done by icepak/fluent?
I know that maybe I can change the case file to use UDF for simulation but FLUENT's case format is not very clearly and has not official FLUENT case file format documentation. Is there any people can give some suggestions? thanks a lot! |
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 08:51 |
Heat pipe simulation in CFX | abymathew | CFX | 1 | November 3, 2015 17:31 |
3D simulation of buried pipe in Fluent | amir_051 | FLUENT | 1 | October 23, 2015 18:03 |
Simulation with UDF for species mass fraction and velocity profile | virgy | Fluent UDF and Scheme Programming | 8 | February 7, 2012 04:30 |
FDTD Simulation of flow through tapered pipe | Jim | Main CFD Forum | 3 | December 25, 2006 10:56 |
