July 1, 2017, 10:01 |
DEFINE_ON_DEMAND Macro
Ahmad Zueter
Rep Power: 9 |
Hello all
I am still new to DEFINE_ON_DEMAND macro and I am trying to learn it first using simple problems. I am modeling flow inside a tube exposed to heat flux. Right now, I am trying to find the average wall temperature at the outlet. Here is the code: ------------------------------------------ #include "udf.h" DEFINE_ON_DEMAND(get_temperature) { Domain *d; /*Declare the fluid domain pointer*/ d = Get_Domain(1); int IDo=9; /*Zone Number (Thread No.) of Outlet*/ Thread *to; /*Declare Outlet Thread*/ face_t f; /*Declare f as face (this will be used in looping*/ to=Lookup_Thread(d,IDo); /*Find Outlet boundary thread location*/ real Too; /*Mean Outlet T*/ real Tfo; /*To be used as below/* /*Sum of T*/ real TfoT=0; /*Used to calculate total T*/ real A[ND_ND]; real area; /*area of each face*/ real areaT=0; /*used to calculate total area*/ begin_f_loop(f,to) { F_AREA(A,f,to); /*the output of this func is A (which is calculated as vector in fluent)*/ area=NV_MAG(A); /*Find the value of A*/ Tfo=F_T(f,to)*area; /*Find the weighted temperature at each face*/ areaT=areaT+area; TfoT=TfoT+Tfo; } end_f_loop(f,to) Too=TfoT/areaT; printf("outlet_temp= %f", Too); F_UDMI(f,to,5)=Too; } ------------------------------------------ It is compiled successfully and I am able to see the the function under "execute demand window". However, when execute it, nothing happens and the value of F_UDMI(f,to,5) does not change. However, I should mention that after compiling, I get this message (note the highlighted): ----------------------------------------------- Copied C:\Users\TEMP.HW.000\Desktop\SecondNanoTrySaveLast Try.c to sdfsdfge\src Creating user_nt.udf file for 3d ... (system "copy "C:\PROGRA~1\ANSYSI~1\v150\fluent"\fluent15.0.7\sr c\makefile_nt.udf "sdfsdfge\win64\3d\makefile" ") 1 file(s) copied. (chdir "sdfsdfge")(chdir "win64\3d")# Generating ud_io1.h SecondNanoTrySaveLastTry.c # Generating udf_names.c because of makefile SecondNanoTrySaveLastTry.obj udf_names.c udf_names.c(9) : warning C4113: 'void (*)()' differs in parameter lists from 'void (*)(void)' # Linking libudf.dll because of makefile user_nt.udf udf_names.obj SecondNanoTrySaveLastTry.obj Microsoft (R) Incremental Linker Version 12.00.21005.1 Copyright (C) Microsoft Corporation. All rights reserved. Creating library libudf.lib and object libudf.exp Done ----------------------------------------------------- When I try to interpret, the following errors occur: ---------------------------------------------------------- Error: C:\\Users\\TEMP.HW.000\\Desktop\\SecondNanoTrySave LastTry.c: line 6: parse error. Error: C:\\Users\\TEMP.HW.000\\Desktop\\SecondNanoTrySave LastTry.c: line 7: parse error. Error: C:\\Users\\TEMP.HW.000\\Desktop\\SecondNanoTrySave LastTry.c: line 8: parse error. Error: C:\\Users\\TEMP.HW.000\\Desktop\\SecondNanoTrySave LastTry.c: line 9: to: undeclared variable ------------------------------------------------------------ Any help is really appreciated |
