Helping to compile the UDF file
Old   June 29, 2017, 05:28
Default Helping to compile the UDF file
maslan
bulu789 is on a distinguished road
Can someone compile the UDF file into ANSYS fluent v17.2 or v18.0. I cannot compile and load the UDF file. I've tried all the solution such as using VS2013 command prompt and I still get the error:-
"the udf library you are trying to load is not compiled for 2d on the current platform"
#include "udf.h"
DEFINE_SDOF_PROPERTIES(sdof_props, prop, dt, time, dtime)
real cg;
real k = 1 * 1.26*1.26;
cg = DT_CG(dt)[1];
prop[SDOF_MASS] = 1;
prop[SDOF_LOAD_F_Y] = -k*cg;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
bulu789 is offline   Reply With Quote
Old   July 1, 2017, 07:58
maslan
I still get the error. I followed all your steps in the video but I still get the error.
Opening library "D:\AAPROJECT\PROJECT_files\dp0\FFF\MECH\libudf".. .
Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the current platform (win64).
The system cannot find the file specified.
D:\AAPROJECT\PROJECT_files\dp0\FFF\MECH\libudf\win 64\2d\libudf.dll
Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the current platform (win64).\n\nThe system cannot find the file specified.
\n\nD:\AAPROJECT\PROJECT_files\dp0\FFF\MECH\libudf \win64\2d\libudf.dll
Error Object: #f
Old   July 4, 2017, 06:53
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
What version of VS2013 did you use?
MayTheFlowBeWithYou is offline   Reply With Quote
Old   August 27, 2017, 18:53
Ivanrips's Avatar
Roger Iván
Ivanrips is on a distinguished road
Hi I have 2017 version, but with 2013 should works, you try open prompt win 64 maybe for this reason doesnt Works. Regards
Sent from my HUAWEI VNS-L21 using CFD Online Forum mobile app
Ivanrips is offline   Reply With Quote
Old   August 28, 2017, 22:40
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
In th libudf folder there is usually a log file. the error must be there.
Please, uninstall all the visual studio you have. don't leave anything. and install visual studio express 2012 for windows. that should work. you don't even have to run fluent from the command line
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   August 30, 2017, 06:15
pakk will become famous soon enough
You are now showing the errors that you see when you click "load". To get help, show the errors that you see when you click "build".
pakk is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
