udf code:hydrogenation raction
Old   June 28, 2017, 12:27
Default udf code:hydrogenation raction
Mat
mataus is on a distinguished road
Hai folks
I am new to this fluent UDF coding and I would like to write a UDF for energy source term for hydrogen absorption in metal hydride.
The equations used in this reaction are given below
ds=ρ_s⋅wt⋅(1-ε)([h+T_s (C_pg-C_ps )]/M_g )).dX/dt
dX/dt=C_a⋅(((p-p_eq ))/p_eq )⋅(exp((-E_a)/(R_g*T_s )))⋅2/3⋅((1-X)^(2/3)/(1-(1-X)^(1/3) ))
X=1-[1-√({C_a *(((P-P_eq ))/P_eq )*(e^(((-E_a)/(R_g*T_s )) ) )*t} )]^3
Peq=(h/(R_g T_s ))-(s/R_g )*〖10〗^5
I wrote udf but,,I found some errors when it interpreted .the udf code and errors are given, I really expect some advice...
#include "udf.h"
#define h -75000 //(J/mol)
#define s -135.6 //(J/mol.K)
#define Rg 8.314 //(J/mol.K)
#define Ca 2.9e8 //(1/s)
#define Ea 124 //(J/mol)
#define rho_s 1800 //(kg/m3)
#define epsilon 0.31
#define Cpg 14000 //J/(kg.K)
#define Cps 1545 //J/(kg.K)
#define por 0.5
#define wt 0.06
#define M_g 0.002 //kg/mol
DEFINE_ON_DEMAND(Pellet)
Domain *d;
int zone_id=5;
Thread *t = Lookup_Thread(d,zone_id);
cell_t c;
d = Get_Domain(1); /* Get the domain using ANSYS Fluent utility */
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0) = 0;
end_c_loop(c,t)
DEFINE_ADJUST(ReactionR,d)
int zone_id=5;
cell_t c;
real P_eq;
real dxdt;
real physical_dt;
real cond;
real ts;
real P;
ts=C_T(c,t);
P=C_P(c,t) /* get cell pressure */
thread_loop_c(t,d)
begin_c_loop(c,t)
P_eq=exp((h/(Rg*ts))- (s/Rg))*pow(10,5);
C_UDMI(c,t,1)=P_eq; /* calculate equilibrium pressure*/
cond=(P/C_UDMI(c,t,1))-1;
if(cond>0)
physical_dt=RP_Get_Real("physical time step")
C_UDMI(c,t,2)=1-pow((1-(sqrt(Ca*((P/C_UDMI(c,t,1))-1)* exp(-Ea/(Rg*ts)))* physical_dt)),3);/* calculate reacted fraction*/
dxdt=(2/3)*Ca*((P/C_UDMI(c,t,1))-1)*exp(-Ea/(Rg*ts))*((pow((1-C_UDMI(c,t,2)),(2/3)))/(1-(pow((1-C_UDMI(c,t,2)),(1/3)))));/* calculate reacted fraction*/
else
dxdt=0;
C_UDMI(c,t,3)=dxdt;
end_c_loop(c,t)
DEFINE_SOURCE(heat_generation,c,t,ds,eqn)
real q_a;
q_a=((rho_s*wt*(1-por)*(h+ (ts*( Cpg- Cps))))/ M_g)* C_UDMI(c,t,3);
ds[eqn]=0;
C_UDMI(c,t,4)=q_a; /* Memory allocation for storing 'heat generation' */
return q_a;
The errors are
1. line 46: parse error.
2. line 46: parse error.
3.c_loop_last: undeclared variable
Thank you
mataus is offline   Reply With Quote
Old   June 29, 2017, 07:56
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
You missed the ; after P=C_P(c,t).
Do not use the // for comments in udf. Some compilers don't understand it. Only use /* */.
KaLium is offline   Reply With Quote
Old   June 30, 2017, 02:45
Mat
thanks for the reply.
I have changed the udf as per your direction but still experiencing one error.
Error: received a fatal signal (Segmentation fault).
Error Object: #f
any help??
Old   July 3, 2017, 07:31
KaLium's Avatar
Kal-El
Have you defined the UDM in fluent?
Old   July 3, 2017, 08:02
Mat
yes, I have assigned 4 udms.
Old   July 3, 2017, 09:00
KaLium's Avatar
Kal-El
You need 5 UDMs
(UDM-0, UDM-1, UDM-2, UDM-3, UDM-4)
Old   July 3, 2017, 09:38
Mat
Thank you.
I changed UDM to 5...but still error persists..
Old   July 3, 2017, 10:57
KaLium's Avatar
Kal-El
Originally Posted by mataus View Post
Thank you.
Are you sure that the zone_id is correct?
Old   July 3, 2017, 11:02
KaLium's Avatar
Kal-El
Is also missing ;
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
