Is it possible that multi-phase flow shows gradation of volume fraction?
Old   June 23, 2017, 15:16
Default Is it possible that multi-phase flow shows gradation of volume fraction?
Jihyeon Kim
kjh9537 is on a distinguished road
Hello everyone,
I'm doing project to simulate slug flow in the pipe.
The flow is 2-phase consisting of oil and gas. To achieve slug frequency, I set fluctuating time-dependent oil volume fraction from 0 to 1 using UDF.
*****I attached my code.********
I wanted to observe flow regime. however my calculation shows gradation for the volume fraction... like below
In my understanding, 2 phase flow forms clear interface between each phase, but my result shows gradation of volume fraction as if oil/gas I set has same phase.
I quadruply cheked my setting or UDF in the simulation and then tried to find the reason in everyway, but couldn't find any clue.
May I ask your opinion that if it can still show the gradation for phase volume fraction in 2 phase flow though it is properly set?
If it doesn't, could you share any clue came up with?
Below is summary of my setting :
Phase 1 : air (default material in Fluent)
Phase 2 : oil (modified density and viscosity from diesel liquid which is default material in Fluent)
Inlet velocity of mixture : 8m/s
Inlet Phase 1 volume fraction : N/A
Inlet Phase 2 volume fraction : UDF (code is attached in this thread)
Phase 2 volume fraction changes between 0 and 1 every 0.1 seconds.
File Type: c fractionoil.c (670 Bytes, 13 views)
kjh9537 is offline   Reply With Quote
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
Mass fraction and volume fraction eric weddle CFX 0 September 26, 2011 06:02
How to set volume fraction in two phase flow Kamel FLUENT 2 March 23, 2007 01:06
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
