Help with my proleme pls , i need it for my comunication next monthe
Old   June 22, 2017, 06:22
Smile Help with my proleme pls , i need it for my comunication next monthe
Bagané Youssef
Youssef18 is on a distinguished road
Hello all,
wen i try to compile my udf i have this error :
air.c ..\..\src\air.c(31) : error C2198: 'SV_is_point_in_cell'˙: pas assez d'arguments pour un appel
..\..\src\air.c(75) : error C2198: 'SV_is_point_in_cell'˙: pas assez d'arguments pour un appel
pls help me i need to fix this
#include "udf.h"
#include "dpm.h"
Global Variables
real air_c_centroid[ND_ND]; /* Centroid of the injection cell */
real air_velo_momentum = 0.0;
real air_mass_stream = 6.125e-3; /* Mass steam used for mass source
and momentum source, in kg/s */
real air_c_volume; /* Volume of the injection cell */
extern real inj_pos[ND_ND];
extern real velo_momentum;
Define the mass source of air exists in the marked cell.
DEFINE_SOURCE(air_mass_source,c,t,dS,eqn)
#if !RP_HOST /* Compile this section for computing processes only
(serial and node) */
real air_mass_source;
CX_Cell_Id cx_cell; /* Define the current cell */
cell_t c_mark = 0; /* Define and initial the marked cell */
Thread *t_mark = NULL; /* Define and initial the marked thread */
if (inj_pos[0] != 0.) /* Excludes this variables as 0.0
in the other computer node or host */
if(SV_is_point_in_cell(&cx_cell,c,t,inj_pos))
/* If the injection point in this cell */
c_mark = RP_CELL(&cx_cell); /* Get the marked cell */
t_mark = RP_THREAD(&cx_cell); /* Get the thread of this
marked cell */
C_CENTROID(air_c_centroid,c_mark,t_mark); /* Get the cell
centroid of the
marked cell*/
air_c_volume = C_VOLUME(c_mark,t_mark); /* Get the volume of
the cell from ANSYS
FLUENT*/
air_mass_source = air_mass_stream / air_c_volume; /* Mass
source */
dS[eqn] = 0; /* No dependent variables of
the transport equation */
Message("\n****************air source*****************\n");
Message("\n air inj_pos: [%g, %g, %g]\n",
inj_pos[0],inj_pos[1],inj_pos[2]);
Message("\n air source centroid: [%g, %g, %g]\n",
air_c_centroid[0],air_c_centroid[1],air_c_centroid[2]);
else air_mass_source = dS[eqn] = 0;
return air_mass_source;
#endif /* !RP_HOST */
Define the momentum source of air exists in the marked cell.
DEFINE_SOURCE(air_momentum_source,c,t,dS,eqn)
#if !RP_HOST
real air_momentum_source;
air_velo_momentum = RP_Get_Real("air/velo_momentum");
/* initial velocity used for momentum source in DEFINE_SOURCE */
/* To set up this user Scheme variable in cortex type */
/* (rp-var-define ' air/velo_momentum 1 ' real #f) */
/* After set up you can change it to another variable: */
/* (rpsetvar ' air/velo_momentum 34) */
CX_Cell_Id cx_cell;
cell_t c_mark = 0;
air_momentum_source = air_mass_stream * air_velo_momentum
/ air_c_volume;
dS[eqn] = 0;
else air_momentum_source = dS[eqn] = 0;
return air_momentum_source;
Youssef18 is offline   Reply With Quote
Old   June 22, 2017, 07:02
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
If you look this example: https://www.sharcnet.ca/Software/Flu...udf/node72.htm
RP_Cell() might need the #include "surf.h"
KaLium is offline   Reply With Quote
Old   June 22, 2017, 07:10
Exclamation
Bagané Youssef
thx for ur answer, but i try it nd i still have the same problem
Old   June 22, 2017, 09:25
KaLium's Avatar
Kal-El
There were also some other differences between your code and the example. Maybe you should copy the example as much as possible.
i need help following problem pls pls help gmani CFX 4 March 31, 2009 10:39
