compilation of udf in fluent
Old   June 14, 2017, 06:09
Default compilation of udf in fluent
shekh abdullah
enyatabdul is on a distinguished road
hi everyone
i am facing problem in compiling udf for different velocity inlet in fluent.
please help me how to compile udf. i am attaching picture of error which i am facing. please help..
enyatabdul is offline   Reply With Quote
Old   June 14, 2017, 08:05
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
Are you using fluent on windows?
Did you make that libudf on serial fluent? Easiest way to fix this is simple to make a new libudf with parallel fluent and then use that new libudf.
KaLium is offline   Reply With Quote
Old   June 15, 2017, 03:54
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
What have you done to solve your problem, if you google your problem, you will find tons of people on cfd-online who fixed their problem
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 15, 2017, 04:09
ivan
icornejo is on a distinguished road
Basically open the problem in parallel mode, compile and load the library and done. You must compile the library in the very same computer that you will run the problem, because, the compilation is specific for the computer arquitecture (cores, SO, etc). If you compile the library in one pc and then run the case in another one you have this kind of problem.
Sent from my SM-T810 using CFD Online Forum mobile app
icornejo is offline   Reply With Quote
Old   June 15, 2017, 04:59
UP
enyat is on a distinguished road
yes, I am using fluent in windows.
enyat is offline   Reply With Quote
Old   June 15, 2017, 05:12
shekh abdullah
sir please guide me how to compile libudf.
The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
above error is always showing..
Old   June 15, 2017, 06:13
sfn
Alexander
sfn is on a distinguished road
This error usually appears when you use x32 compiler on x64 system. You have to make sure that you use correct compiler. Sometimes it's very tricky to set 64x compiler for ansys, search this forum and you'll find some solutions
sfn is offline   Reply With Quote
Old   June 16, 2017, 11:06
imane EL JIRARI
imane.E-J is on a distinguished road
hello ,
I am a beginner in fluent .I want to make a dynamic mesh but i have a problem with the udf file .IT'sconcerning a moving solid through a two fluid .I sit necessary to have a compied udf to do such simulation thank you .also i need to know how de border betwin two phases (air and a liquid is defined )
imane.E-J is offline   Reply With Quote
Fluent in-built models' UDF Population Balance Michaeladam FLUENT 2 June 29, 2019 06:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
How does FLUENT process an UDF!!!!???? Bharadwaj B S Fluent UDF and Scheme Programming 31 March 9, 2015 07:32
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
