UDF for mass and heat source with heat transfer
Like Tree14Likes
Old   June 8, 2017, 06:03
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
Originally Posted by rajendra1 View Post
I have found rise in temperature with constant mass source input. But solution stopping after every iteration. may be I shall check the formula again. But again there is nothing stored in UDM.
I am not really sure whether I shall use DEFINE_EXECUTE_AT_END or DEFINE_ON_DEMAND. please put some light .......what I know is that former is executed at the end of time step and later in the beginning.
Can I define initial values to in C_UDMI using DEFINE_INIT macro?
DEFINE_EXECUTE_AT_END is used at the end.
DEFINE_ADJUST is used at the beginning
DEFINE_ON_DEMAND is used with manual command.
I would use a DEFINE_ON_DEMAND for initialization:
DEFINE_ON_DEMAND (udm_init)
  Thread *thread;
  cell_t cell;
  Node *node;
  Domain *domain = Get_Domain(1);
   thread_loop_c(thread,domain)
      begin_c_loop(cell,thread)
      C_UDMI(cell,thread,0) = 0.0;
      C_UDMI(cell,thread,1) = 0.0;
      C_UDMI(cell,thread,2) = 0.0;
      C_UDMI(cell,thread,3) = 0.0;
      C_UDMI(cell,thread,4) = 0.0;
      end_c_loop(cell,thread)
You have to run macros like this manual: http://jullio.pe.kr/fluent6.1/help/h...-use-on-demand
You can also use fluent patch panel if you don't want to use UDF: https://www.sharcnet.ca/Software/Flu...g/node1384.htm
rajendra1 likes this.
KaLium is offline   Reply With Quote
Old   June 8, 2017, 06:22
KaLium's Avatar
Kal-El
DEFINE_SOURCE(mass_source,c,t,dS,eqn)
dS[eqn] = C_UDMI(c,t,1);
return C_UDMI(c,t,0);
DEFINE_SOURCE(energy_source,c,t,dS,eqn)
dS[eqn] = C_UDMI(c,t,4);
return C_UDMI(c,t,3);
So you have non-zero mass source with this code? how is your solution stopping?
Old   June 9, 2017, 11:13
rajendra1 is on a distinguished road
Since heat source is dependent on mass source and there is increase in temperature, so I think mass source is positive.
Thank you very much for suggestion regarding DEFINE_ON_DEMAND macro.
I have added it to my udf but again solution is stopping after every time step showing "FLUENT received fatal signal (ACCESS VIOLATION)". It proceeds if I calculate it further but only for single time step.
rajendra1 is offline   Reply With Quote
Old   June 9, 2017, 13:34
KaLium's Avatar
Kal-El
Maybe you should replace your execute_at_end macro with adjust-macro.
Also add the thread - loop. Similar than in my define_on_demand code.
Old   June 9, 2017, 15:15
okay I will try it.
Old   June 10, 2017, 21:23
Hi KaLium,
I have finally moved forward from the error, thank you very much for your suggestions without your suggestions it would have been very difficult to move further.
I have used DEFINE_EXECUTE_AT_END, should also be possible by using DEFINE_ADJUST, I shall try it.
But again I did not find anything stored in UDM.
Old   June 10, 2017, 21:33
  Thread *thread;
  cell_t cell;
  Node *node;
CAN we use your suggested code in this fashion? do we need specify node?
real x[ND_ND];
Thread *thread;
cell_t cell;
//Node *node;
int zone = 3;
thread =Lookup_Thread(domain,zone);
Old   June 12, 2017, 07:52
KaLium's Avatar
Kal-El
  Thread *thread;
  cell_t cell;
  int zone = 3;
I would try this.
You don't need the "node". I copied that from my old code as a mistake.
Old   June 12, 2017, 09:10
KaLium's Avatar
Kal-El
is enough if you are using your udf in one cellzone only.
Old   June 12, 2017, 14:17
interesting ..thanks for clarification.
I have tried to use DEFINE_ADJUST instead of DEFINE_EXECUTE_AT_END but not fruitful so far, however it solves problem when I use DEFINE_EXECUTE_AT_END and also storing values in UDM.
Old   June 12, 2017, 14:46
KaLium's Avatar
Kal-El
Do you mean that your code is working now?
Old   June 12, 2017, 15:55
yes it is working.
KaLium likes this.
Old   June 13, 2017, 03:56
KaLium's Avatar
Kal-El
Ok! Then you can forget the Define_adjust and just use the code that works.
How did you fix the code?
Old   June 13, 2017, 12:47
I was not using thread loop, so just added it and it worked.
Old   June 14, 2017, 04:15
so basically I have used DEFINE_INIT and DEFINE_EXECUTE_AT_END .........and apparently the problem was with DEFINE_EXECUTE_AT_END macro ie. the missing thread loop as I have said.
Old   October 13, 2017, 05:04
maitray's Avatar
Maitray sharma
maitray is on a distinguished road
Dear Friends,
I am trying to solve heat transfer problem.
The geometry is shell and tube type. please see attachment for the picture of model.
Problem description:
heat is generation takes place in tube and it is to be transferred to the shell side through the cylinder wall. There is no problem when I am trying to solve the problem in fluent (workbench project) by giving constant heat source as input. BUT when I am trying to calculate mass generation and heat generation with the help of UDF, fluent says: fluent received fatal signal (access_violation). I have tried different ways to rectify the error but failed so far.
Boundary conditions are,
gas inlet (tube (inner) inlet) at 20e+05 Pa. pressure, 300 K temp.
gas outlet (tube (inner) outlet) adiabatic wall (so there is no outlet only inlet on tube side)
coolant inlet (shell side (annular section)) 300 K temp.
coolant outlet (shell side (annular section))
Convetive wall (inner cylinder surface)
Convetive wall Shadow (inner cylinder surface)
Adiabatic wall (outer cylinder surface)
I have coupled convective wall and its shadow in boundary conditions. Also tried to calculate heat flux on the convective wall using DEFINE_HEAT_FLUX macro.
I have tried to give initial values using DEFINE_INIT MACRO in the gas tube because I want uniform pressure in the tube.
I am trying to calculate mass source and hence heat source using DEFINE_SOURCE MACRO
I am using Interpreted UDF. It gets interpreted, in fluent initialization gets done but it again gives same error ie. "fluent received fatal signal (access_violation)".
I need help from you guys, please see the code and tell me where I am wrong, I will be very grateful for you suggestions.
UDF CODE:
UDF for initializing flow field variables
DEFINE_INIT(my_init_func,d)
cell_t c;
Thread *t;
real xc[ND_ND];
/* loop over all cell threads in the domain */
thread_loop_c(t,d)
/* loop over all cells */
begin_c_loop_all(c,t)
C_CENTROID(xc,c,t);
C_T(c,t) = 300.;
C_P(c,t) = 2000000.;
C_U(c,t) = 0.;
C_V(c,t) = 0.;
C_W(c,t) = 0.;
end_c_loop_all(c,t)
/* UDF for specifying an absorption source term in a pressure and temperature*/
DEFINE_EXECUTE_AT_END(source_calculation)
Domain *d;
Thread *t;
cell_t c;
real time = CURRENT_TIME;
real temp, Pg, Peqa, mab, m;
int zone=7;
d=Get_Domain(1);
t=Lookup_Thread(d,zone);
begin_c_loop(c,t)
temp=C_T(c,t);
Pg=C_P(c,t);
Peqa=1000*exp(Aab-Bab/temp);
mab=-Ca*exp(-Ea/(Rg*temp))*log(Pg/Peqa)*(Psat-Pemp-C_UDMI(c,t,2)); /* mass rource kg/m^3 S*/
m=mab;
C_UDMI(c,t,0) = m;
C_UDMI(c,t,1) = 0.0; /*derivative term in mass source*/
C_UDMI(c,t,2) = -C_UDMI(c,t,0)*CURRENT_TIMESTEP+C_UDMI(c,t,2);
C_UDMI(c,t,3) = C_UDMI(c,t,0)*(delta_H+temp*(C_pg-C_ps));
C_UDMI(c,t,4) = 0.0;/*derivative term in energy source*/
end_c_loop(c,t);
/**************udf for Wall Heat flux on convective wall *************************** */
real h = 0.0; /* heat transfer coefficient (W/m^2 K)
DEFINE_ADJUST(htc_adjust, domain)
/* Define the heat transfer coefficient. */
h = 120;
(heat_flux, f, t, c0, t0, cid, cir)
cid[0] = 0.;
cid[1] = h;
cid[2] = h;
cid[3] = 0.;
I thank you in advance.
For this metal hydride absorption problem, why are you giving initial pressure to all cell zone instead to giving the pressure at the inlet of cylinder?
maitray is offline   Reply With Quote
define_init, define_source, heat flux udf, mass source term, source energy term
UDF for heat transfer coeff. in porous media parvaz747 FLUENT 0 November 16, 2016 13:35
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Problem in UDF time dependent vloumetric heat source eng_yasser_2020 Fluent UDF and Scheme Programming 0 March 30, 2014 09:07
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
UDF - Heat transfer coefficient kulasekharan FLUENT 3 August 12, 2004 08:09
