Zone motion udf error in Fluent
Old   May 25, 2017, 08:26
Default Zone motion udf error in Fluent
Sigurd TH
Sigurd is on a distinguished road
Hi!
I am trying to compile a udf for a rotating shaking flask, or an Orbitally Shaken Bioreactor for those of you familiar with those.
The code I am using is pretty basic I think, but it returns an error of:
udf_names.c(7) : error C2059: syntax error : '}'
udf_names.c(8) : warning C4034: sizeof returns 0
and this is the code I am using:
#include "udf.h"
#define pi 3.141592654
#define d_o 0.025 //shaking diamter [m]
 DEFINE_ZONE_MOTION(rotation,omega,axis,origin,velocity,time,dtime)
 real omega_o, theta, r_o;
 omega_o=pi*2; //angular velocity of shaker table [rad/s]
 *omega=-omega_o; //angular velocity of shake flask [rad/s]
 theta=omega_o*(time+dtime); //angular position of shake flask [radians]
 r_o=d_o/2; //shaking radius [m]
 origin[0]=r_o*cos(pi+theta);
 origin[1]=r_o*sin(pi+theta);
 origin[2]=0;
Any help would be greatly appreciated!
Thanks
Sigurd
Sigurd is offline   Reply With Quote
Old   October 24, 2018, 10:24
Vincent Wiegmann
MandatoryMadness is on a distinguished road
Hi!
Sorry to revive this thread
I am currently working on a similar problem in Fluent. Have you found a solution for the shake flasks? My UDF code looks similar and can be compiled etc. but the movement of the mesh is not right.
This is the code:
#include "udf.h"
#define PI 3.14592654
DEFINE_ZONE_MOTION(rotation, omega, axis, origin, velocity, time, dtime)
real theta0, theta1, omegac, omegar, rdar, ox, oy;
omegar = -20.94;
omegac = -omegar;
rdar = 0.0125;
theta0 = PI;
theta1 = omegar*(time+dtime);
*omega = omegac;
origin [0] = rdar*cos(theta0+theta1);
origin [1] = rdar*sin(theta0+theta1);
origin[2] = (0,0);
MandatoryMadness is offline   Reply With Quote
Old   October 29, 2018, 10:38
obscureed is on a distinguished road
Hi Vincent,
Does that code really compile? "origin[2] = (0,0);" doesn't look like correct C to me.
Moving the origin is a rather mind-bending thing to do here. If you just want oscillatory rotation, the origin stays constant. If you want oscillatory rotation plus some other motion, you probably need to add some translation velocity. For the motion of a beaker on a tray, it could all be translation velocity.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   October 29, 2018, 13:29
Vincent Wiegmann
Hi Ed,
Thanks for the input! The code compiles fine, I will try another format just to make sure this is not the cause of the incorrect movement.
Unfortunately, this setup requires two motions. 1) The vessel rotating around the origin and 2) the vessel rotating around itself in the opposite direction - so effectively the vessel always faces the same direction during the rotation.
How would you add a translation velocity?
Many thanks and regards
Vince
Old   October 30, 2018, 08:42
Hi Vince,
Well, I'll put it another way: what do you intend to be the result of "origin[2] = (0,0);"? It doesn't look familiar to me.
(Rotation about one axis + equal and opposite rotation about another axis) = no rotation, only translation. Look at the velocity argument in DEFINE_ZONE_MOTION.
A couple of very minor comments while I'm here: You will find that M_PI is already defined for pi. You can try to finesse the time for evaluating functions -- time, or time+dtime, or something in between -- but in general it's easier to stick with time.
Good luck!
Ed
Old   January 21, 2020, 10:53
Default Query related to zone motion
Tanuj Srivastava
S_Tanuj is on a distinguished road
I am trying to give the zone motion using UDF. Below is the code attached. Though it shows no error on compilation, zone does not seem to rotate as per code. Geometry is simple 2-D closed-loop pipe and origin is at the bottom. Is there anything wrong in UDF?
#include "udf.h"
#define Freq 0.1
#define angular_freq 2.0*M_PI*Freq
#define tetmax 15.0*M_PI/180
DEFINE_ZONE_MOTION(shm, omega, axis, origin, velocity, time, dtime)
*omega = tetmax*angular_freq*cos(angular_freq*time);
velocity[0] = 0.0;
velocity[1] = 0.0;
velocity[2] = 0.0;
omega[0] = 0.0;
omega[1] = 0.0;
omega[2] = *omega;
S_Tanuj is offline   Reply With Quote
Old   January 22, 2020, 02:14
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
remove * before omega
was:
 *omega
to be:
 omega
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 22, 2020, 02:23
Tanuj Srivastava
Earlier I did the same but there was error because of not including "*", and the error was-
zone_motion.c
..\..\src\zone_motion.c(8) : error C2440: '=' : cannot convert from 'double' to 'real *'
..\..\src\zone_motion.c(16) : error C2440: '=' : cannot convert from 'real *' to 'real'
After including "*", it easily compiled.
Old   January 22, 2020, 04:04
Alexander
#include "udf.h"
#define Freq 0.1
velocity[0] = 0.0;
velocity[1] = 0.0;
velocity[2] = 0.0;
omega[0] = 0.0;
omega[1] = 0.0;
omega[2] = tetmax*angular_freq*cos(angular_freq*time);
best regards
Old   November 30, 2020, 03:34
Tanuj Srivastava
Originally Posted by AlexanderZ View Post
#include "udf.h"
#define Freq 0.1
velocity[0] = 0.0;
velocity[1] = 0.0;
velocity[2] = 0.0;
omega[0] = 0.0;
omega[1] = 0.0;
The code shoes no error BUT using frame motion in "cell zone boundary condition" motions is NOT OBSERVED. What could be the reason for this. Though mass flow rate fluctuate which point out towards effect of UDF.
fluent, udf, zone motion
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
[Resolved] GPU on Fluent Daveo643 FLUENT 4 March 7, 2018 09:02
[ANSYS Meshing] Problem UDF for sinusoidal wall motion - FLUENT avd28 ANSYS Meshing & Geometry 0 August 21, 2015 15:46
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
Incorrect CG motion UDF on Zone ... (assuming no motion) Irenedea Fluent UDF and Scheme Programming 0 March 21, 2014 03:45
