Fluent udf Error: received a fatal signal (Segmentation fault) Error Object: #f
Like Tree1Likes
Old   April 13, 2018, 05:06
yanghai
yanghai is on a distinguished road
Originally Posted by obscureed View Post
Hello Yanghai,
I cannot see any immediate problem with your UDF, so I think you will have to debug it, either by starting very simple and adding elements, or by removing elements from your current UDF:
F_PROFILE(f,t,i)=100;
F_PROFILE(f,t,i)=100+log(101325.);
F_PROFILE(f,t,i)=100+log(RP_Get_Real("operating-pressure"));F_PROFILE(f,t,i)=100+log(F_P(f,t)+RP_G et_Real("operating-pressure"));
Looking up an RP value has a cost, so if the model is large enough that the UDF execution time matters, it would be better to define a variable p_op, assign to p_op the RP value before the face loop, then use p_op inside the loop.
Please can you describe when the error occurs, and specify the error message? (This is one difficulty with re-using an old thread: it is difficult for us to know which of the past situations resembles your situation.)
The temperature here is in Kelvin -- are temperatures around 110K correct for your model?
If your model is massively disrupted by the UDF (or any other influence) such that F_P goes below -p_op, then the log() will be given a negative value, which will cause trouble. It might or might not be worth guarding against this kind of catastrophic error, depending on the probability of the disruption and how much you care about a crash.
Good luck!
Ed
ED, thanks for your reply, like the pakk said, i try this way, but it still have the error. the error is : received a fatal signal (Segmentation fault). when i click the Initialization, the error will occur. just like i said in ((ask) temperature profile that include the pressure i change the profile of temperature like :F_PROFILE(f,t,i)=100 that don't include the F_P(f,t), it is OK.
so do you know, where is the problem? thank you so much.
yanghai is offline   Reply With Quote
error, fluent - udf
Fatal signal in fluent 6.3.26 NewFluent Fluent UDF and Scheme Programming 5 July 24, 2017 03:08
Fluent15: received a fatal signal (Segmentation fault) lcg44 FLUENT 4 August 29, 2016 13:19
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
fluent 13.0.0 received a fatal signal (SEGMENTATION VIOLATION)) alinik FLUENT 1 January 9, 2014 11:21
A fatal signal (segmentation violation) sutthinan Fluent UDF and Scheme Programming 6 March 16, 2011 19:35
