Defining Cp as a function of temperature and pressure |
May 23, 2017, 06:27 |
Sergen Uysal
Rep Power: 9 |
Hi all,
I do analysis of c-d nozzle with R245fa organic fluid and the fluid is in super-critical region at inlet. Then, the fluid is in vapor region. I can define specific heat constant (Cp) as a function of temperature, but it depends on pressure also. For example, At 432 K (which is my inlet total temperature), Cp is 1.095 kJ/kg-K at 1 bar, it increase up to 3.365 kJ/kg-K at 37 bar which is in supercritical region. I don't know how to define Cp as a function of T and P. I searched but I couldn't find that I want. If it is not possible, which pressure value should I use as a constant to define Cp only as a function of temperature, ? |
June 2, 2017, 08:04 |
Kal-El
Rep Power: 9 |
UDF is possible
UDF for specific heat http://www.afs.enea.it/project/neptu...udf/node51.htm This option is not available with the premixed, non-premixed and partially premixed models, and should be used as a compiled UDF only. |
June 13, 2017, 12:59 |
Estêvão Lannes Tolentino
Rep Power: 10 |
I'm having a similar problem and I would like to know if this issue has been solved. If so, how was it solved? Thank you. |
June 14, 2017, 04:09 |
Sergen Uysal
Rep Power: 9 |
Thank you KaLium. I have just seen this message, sorry for late reply.
I couldn't define Cp as a function of both T and P. I selected an average pressure value and I define Cp only depends on temperature for my graduation project. @estevaotolentino |
June 14, 2017, 14:01 |
Rep Power: 10 |
Ok, I got it. Thank you for the reply.
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Density as a function of Pressure and Temperature | yenyeskumar | CFX | 0 | November 4, 2011 03:17 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
