How do I export a parameter from one define-function to another?
Old   May 13, 2017, 18:56
Default How do I export a parameter from one define-function to another?
h0rst is on a distinguished road
Hello everyone,
I'm calculating the average temperature by a function hooked by "execute at end". It is a define on demand function.
I need this temperature in a different udf, which is used as an initialization function
How can I export the temperatures from one udf to the other?
Best regards
h0rst
h0rst is offline   Reply With Quote
Old   May 17, 2017, 04:24
KirMaks
kirmaks is on a distinguished road
Hallo,
there are many possible options:
1. You can try to define the global variable which will be used by both UDFs;
2. You may use scheme variable (there is an example in help, search for rpgetvar);
3. You may update some text file and read the value there (will be the slowest).
4. ...
Regards, Maks
kirmaks is offline   Reply With Quote
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 05:30
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 06:47
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
