Accessing neighbouring nodes values
Old   May 10, 2017, 14:26
Default Accessing neighbouring nodes values
sebastian bergman
Tushar_Telmasre is on a distinguished road
Dear Friends,
Is there any macro or variable to access the neighbouring node data. like _M1 will give you value at previous time step.
I need temperature data at neighbouring nodes to calculate gradient.
Can anybody comment?
Tushar_Telmasre is offline   Reply With Quote
Old   May 12, 2017, 05:16
KirMaks
kirmaks is on a distinguished road
Hallo,
I think it's easier to set the expert parameter to store the temporary variable values and the FLUENT will make the work for You. You can use C_T_G(c,t)[0..2] directly then.
There is an example for UDS gradient in help: https://www.sharcnet.ca/Software/Flu...udf/node96.htm
Best regards, Maks
kirmaks is offline   Reply With Quote
Old   May 12, 2017, 07:48
sebastian bergman
Thanks a lot.
That did solve the gradient problem.
nodes coordinates, temperature gradient
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
F_NNODE returns double number of nodes falkon Fluent UDF and Scheme Programming 0 March 8, 2014 07:58
Create some nodes into an existing mesh and accessing to those nodes ooo OpenFOAM Programming & Development 0 November 2, 2013 19:03
Accessing Values of U_general questions harly OpenFOAM 3 December 8, 2008 15:14
Accessing Shear Rate Values in Subroutines Daniel Lattin Siemens 0 January 10, 2007 18:59
