How to select just the wall between Fluid and solid? |
May 7, 2017, 10:42 |
Rep Power: 10 |
Hello everyone,
I try to apply some own heat transfer coefficients between tube and fluid and therefore I need to select just the wall between. In the boundary conditions, the wall is "zone_id 5" and the shadow wall is "zone id 10". Now I want to see if the wallzone is selected right before I do some tests with own HTC. Therefore, I am writing the xyz coordinates to check. Unfortunately, too many zones are selected.* My UDF is: DEFINE_HEAT_FLUX(heat_flux, f, t, c0, t0, cid, cir) { real x[ND_ND]; Domain *d = Get_Domain(1); Thread *thread = Lookup_Thread(d, 5); begin_f_loop(f, thread) { F_CENTROID(x,f,thread); printf("x= %f y = %f z = %f\n", x[0], x[1], x[2]); } end_f_loop(f,thread) Does someone see the problem? Best regards h0rst |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
