reproducing k-omega model UDF/Wall function
Old   May 2, 2017, 17:12
Default reproducing k-omega model UDF/Wall function
ali
alinik is on a distinguished road
Hi all,
I am trying to reproduce the k-w turbulence model using UDF.
I have written all necessary parts and the result that I am getting is in the acceptable range.
The problem that I have right now, and I am not sure how to fix that, is the fact that I have to implement wall function for the cells adjacent to walls. I am not sure how to do that.
Do I have to manually specify velocity for cells in this region?
Does anyone here have any experience on how one can write a wall function in UDF?
Any kind of support is highly appreciatd.
Thanks,
Ali
alinik is offline   Reply With Quote
Old   June 16, 2017, 18:40
ali
I am replying to my own post with the hope of receiving more attention.
Has anybody done the same thing ever before?
Old   July 12, 2017, 15:27
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
If you want to write wall functions in UDF, first of all you must make sure that your y+ location is appropriate.
Then you can give the value of k, omega, U, V etc directly in the DEFINE_ADJUST() to their respective Scalars. You can use 'if' statements check the y+ values.
vcvedant is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Virtual inheritance problem while adding public member function to LES SGS Model konneym OpenFOAM Programming & Development 4 November 4, 2013 12:37
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
