UDF profile for a fluid flow through a valve
Old   May 2, 2017, 06:52
Unhappy UDF profile for a fluid flow through a valve
elia petrogalli
elia.p is on a distinguished road
Good morning to everybody,
I am doing my master thesis on a semi-active control for a secondary damper for a train and i have to check the quality of the numerical model with a CFD simulation by using Fluent. The model of the damper I created is very simple and is composed by a cylinder divided in 2 chambers separated by a piston on which i have 3 valves controlling the fluid flow from one chamber to the other one.
The flow through the valve must be a linear function of the difference of pressure (dP) between the two chambers: when the dP is less then a certain dPx the valve should be closed, then the flow should increase linearly till a certain value of pressure dPy is reached and then the flow must be constant for increasing pressure (this law simulate the real behavior of the valve, who is regulated by a spring).
First i tried to model the valve with a simple porous jump boundary condition , but in this case i could not reproduce the real behavior, because also for small value of dP i had flow through the valves and by increasing dP indefinitely also the flow increased indefinitely (not good). I think the best way to solve my problem is to use an UDF function which calculates the flow receiving by input the pressures in the two chambers, but i have no idea how to write it, also if i read the fluent guide to uff it is still very unintelligible for me.
I ask your help to write me the very general structure i have to give to this function.
Thank you,
Elia
elia.p is offline   Reply With Quote
cylinder, damper, udf, valve
UDF for 3d velocity inlet profile in channel flow Thejas4ansys Fluent UDF and Scheme Programming 0 April 1, 2016 16:09
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
What will be the state or condition in fluid volume when flow is not full? shivasluzz CFX 2 May 17, 2015 03:59
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
