Fluent UDF for Non linear wall temperature gives constant wall T after initialisation
Old   April 20, 2017, 09:13
Default UDF for vapour pressure
Anuja Vijayan
anuarun is on a distinguished road
Hello all,
I have a temperature profile file as my wall BC. My profile file is working fine (as evident from T plots after convergence). I have written a UDF to vary vapour pressure as a function of temperature. I have hooked it to the vapour pressure option while activating mass transfer from liquid to vapour>cavitation. It gets interpreted neatly and solution converges also.Now, the solution obtained is not showing the expected improvement (rather change) when compared to a case where Pv=const.
My UDF looks like this.
#include "udf.h"
/*for Vapour pressure*/
DEFINE_PROPERTY(Vapour_pressure,c,t)
real T = C_T(c,t);
real p_v;
p_v = (0.00329*exp(0.19039*T) - 0.05762)*1000000.0;
return p_v;
How will I know if this is working fine? Do I need to write the UDF specifically in terms of SUB_THREAD, SUPER_THREAD etc. I assumed that since I am calling UDF from vapour pressure options, it will take appropriately. Is that right? Has anybody done something similar? Any help is greatly appreciated. I am stuck here for more than a month.
anuarun is offline   Reply With Quote
Old   May 16, 2017, 11:17
Default Vapour Pressure UDF
Anuja Vijayan
Hello all,
I found that defining temperature BC as a profile file is better than including a UDF especially when I have to include(by interpreting) other UDFs(say for properties in terms of temperature). Now my profile file is working fine. I have written a UDF to vary vapour pressure as a function of temperature. I have hooked it to the vapour pressure option while activating mass transfer from liquid to vapour>cavitation. It gets interpreted neatly and solution converges also.Now, the solution obtained is not showing the expected improvement (rather change) when compared to a case where Pv=const.
#include "udf.h"
real T = C_T(c,t);
real p_v;
return p_v;
Old   May 16, 2017, 11:25
Anuja Vijayan
I am really sorry for the bad editing. My first post was regarding a Temperature UDF for wall temperature not working fine. I have solved it by including a profile file instead of a UDF. That post got deleted while editing.
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 12:30
UDF for linear temperature variation nonstopthinker Fluent UDF and Scheme Programming 2 September 4, 2016 01:36
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 08:29
UDF of linear distribution of temperature in a 2D tank arailos Fluent UDF and Scheme Programming 1 August 19, 2010 15:14
udf variable for wall temperature Kiran FLUENT 0 July 31, 2008 09:31
