Dependent variables for linearized source terms
Old   April 5, 2017, 03:20
Default Dependent variables for linearized source terms
Anders Simonsen
ASimonsen is on a distinguished road
Hi
I'm using DEFINE_SOURCE to define various source terms in my model. In order to increase stability, I'm linearizing the sources. The UDF-manual states the following (Page 127 in Fluent UDF manual for release 18.0):
Note that the source term derivatives may be used to linearize the source term if they enhance the stability of the solver. To illustrate this, note that the source term can be expressed, in general, as Equation 2.10 (p. 127), where Phi is the dependent variable, A is the explicit part of the source term, and B*Phi is the implicit part.
S_Phi = A + B * Phi
I'm specifying source terms for momentum, energy and mass. I've found the following information about the three terms:
Momentum:
- Dependent variable (Phi): Velocity [m/s]
- Unit of A and S_Phi: [N/m^3]
- Unit of B: [(N/m^3)/(m/s)]
Energy:
- Dependent variable (Phi): Temperature [K]
- Unit of A and S_Phi: [W/m^3]
- Unit of B: [(W/m^3)/(K)]
Mass:
- Dependent variable (Phi): ???
- Unit of A and S_Phi: [kg/(s*m^3)]
- Unit of B: [(kg/(s*m^3))/(???)]
As you can see, I don't know what the dependent variable is for mass sources. Can anyone help me with that?
Regards Anders
ASimonsen is offline   Reply With Quote
define_source, source term
Assigning time dependent heat Source terms Asghari_M OpenFOAM Programming & Development 25 August 3, 2015 01:19
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
