How to build divergence of volume fraction gradient in UDF?
Old   April 1, 2017, 14:28
Default How to build divergence of volume fraction gradient in UDF?
bss
Bahador
bss is on a distinguished road
I want to calculate 'curvature' in UDF. I have attached formulation of curvature.
'F' is volume fraction.
C_VOF_G(c,t) can calculate gradient of volume fraction
NV_MAG(C_VOF_G(c,t)) can calculate magnitude of volume fraction. I can calculate gradient of volume fraction but My problem is that I can't calculate divergence of volume fraction gradient in UDF.
Thank you in advance.
bss is offline   Reply With Quote
Old   February 11, 2021, 14:53
ANOOP K UNNI
anoop.k.unni is on a distinguished road
Hi did you solve?
anoop.k.unni is offline   Reply With Quote
Old   February 12, 2021, 01:47
pakk will become famous soon enough
Going from the gradient to the divergence (in standard Cartesian coordinates) is super simple... Just sum them.
Maybe I don't understand the problem?
pakk is offline   Reply With Quote
Old   February 12, 2021, 02:14
ANOOP K UNNI
I have written a UDF for a multiphase (of) problem dealing with recoil pressure which has to be added as momentum source term. i have attached a figure which shows a definition of my problem and also udf. can you please check whether i have written in the right way because i am not able to run the case.
#include "udf.h"
#include "sg.h"
#include "sg_mphase.h"
#include "flow.h"
#include "mem.h"
#include "unsteady.h"
DEFINE_ADJUST(vol_gradient, domain)
Thread *t;
cell_t c;
real DVOFNX,DVOFNY,DVOFDNZ;
domain = Get_Domain(6);
/* Fill UDS with the variable. */
thread_loop_c (t,domain)
begin_c_loop (c,t)
C_UDSI(c,t,0) = C_VOF(c,t);
DVOFNX = C_UDSI_G(c,t,0)[0];
DVOFNY = C_UDSI_G(c,t,0)[1];
DVOFNZ = C_UDSI_G(c,t,0)[2];
C_UDMI(c,t,0) = DVOFNX;
C_UDMI(c,t,1) = DVOFNY;
C_UDMI(c,t,2) = DVOFNZ;
end_c_loop (c,t)
begin_c_loop (c,t)
C_UDMI(c,t,3) = NV_MAG(C_UDSI_G(c,t,0));
end_c_loop (c,t)
DEFINE_ON_DEMAND(store_gradient)
Domain *domain;
cell_t c;
Thread *t;
/* Fill the UDM with magnitude of gradient. */
*thread_loop_c (t,domain)
begin_c_loop (c,t)
C_UDMI(c,t,4) = C_UDMI(c,t,0)/NV_MAG(C_UDSI_G(c,t,0));
C_UDMI(c,t,5) = C_UDMI(c,t,1)/NV_MAG(C_UDSI_G(c,t,0));
C_UDMI(c,t,6) = C_UDMI(c,t,2)/NV_MAG(C_UDSI_G(c,t,0));
end_c_loop (c,t)
DEFINE_SOURCE(x_recoil,c,t,dS,eqn)
real x[ND_ND];
real source;
real time;
real temp;
time=RP_Get_Real("flow-time"); //Acquire time from FLUENT solver
C_CENTROID(x,c,t);
temp=C_T(c,t); //Acquire the face centroid location
if (C_T(c,t) >= 3201.)
source=(54715.5*exp(13.14*(temp-(3200)/temp)))*(C_UDMI(c,t,4));
C_UDMI(c,t,7) = source;
dS[eqn] = 0;
else
source = dS[eqn] = 0.;
return source;
//same for y and z
Old   February 12, 2021, 07:31
"not able to run the case" can mean 20 things. Please be more detailed, that makes it much easier to help you.
Old   February 12, 2021, 08:39
ANOOP K UNNI
After initializing the case with adjust gradient hoking and it is showing' Received signal SIGSEGV. MPI Application rank 0 exited before MPI_Finalize()' So, I want to know whether is it because of any mistake in UDF or other (improper boundary conditions,patching issue)
Old   February 12, 2021, 12:22
That is a good question. To find out if your error comes from the UDF or from somewhere else: run it without hooking the UDF! If you don't get an error, the problem was in your UDF.
If you do get a problem: debug! Simplify your UDF, and find out which line causes the error.
curvature, gradients, udf and programming, vof method
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
UDF for Species Mass Fraction Gradient *IN SPECIFIC ZONE * -- e.g. along axis of sym. ksiegs2 Fluent UDF and Scheme Programming 0 February 27, 2011 13:55
