Rakesh
Rep Power: 12 ![]() |
Hi everyone,
I am writing a udf for a dynamic mesh update in parallel solver. I have attached a part of my code. Basically I use a looping macro, that loops across all the faces, then loops the nodes of that face and updates the nodal positions. #if !PARALLEL begin_f_loop(f,thread) { if PRINCIPAL_FACE_P(f,thread) { f_node_loop(f,thread,n) { v = F_NODE(f,thread,n); if (NODE_POS_NEED_UPDATE(v)) { NODE_POS_UPDATED(v); NODE_X(v) = NODE_X(v) + deltax; } } } } end_f_loop(f,thread) The problem is when I use this is parallel, it does not work properly. Basically what it does is, in a parallel solver, the mesh is partitioned along cells. So there are certain nodes which belong to two (or more) faces (or cells). These nodes are updated twice (or more) independently by each of the compute nodes to which they are assigned. The macro (NODE_POS_NEED_UPDATE) does not seem to work in parallel case. Is my observation correct? Could you suggest any other macro that takes care of these shared nodes in a parallel solver? Please let me know your suggestions. Best, R |
commands such as if !RP_HOST or if !RP_NODE have to be used to avoid this problem
Nausheen Sultana
Hi R,
Did you find a solution to the problem? I have similar problems with node count, where the nodes are being counted more than once. |
#4 | |
Alexander
Rep Power: 34 ![]() ![]() |
begin_f_loop_int Code:
begin_f_loop best regards |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues | nathanricks | ANSYS Meshing & Geometry | 0 | September 23, 2015 05:14 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
Dynamic mesh crashes in parallel, but works in serial | 86lolo | FLUENT | 7 | June 24, 2014 05:24 |
Dynamic Mesh- Parallel UDF | DE HEART | Fluent UDF and Scheme Programming | 14 | August 11, 2010 01:29 |
