error in udf
Old   March 25, 2017, 07:45
Default error in udf
NGP
ngonbadipoor@yahoo.com is on a distinguished road
Hi guys
I defined a macro for density, viscosity and conductivity for a flow by udf.when I start the run I received some errors.
what these errors means?
Divergence detected in AMG solver: pressure correction
Divergence detected in AMG solver: temperature
Divergence detected in AMG solver: x-momentum
Divergence detected in AMG solver: y-momentum
Divergence detected in AMG solver: z-momentum
Error at host: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error: floating point exception
Error Object: #f
thanks
ngonbadipoor@yahoo.com is offline   Reply With Quote
Old   March 28, 2017, 04:54
pakk will become famous soon enough
It means that your simulation had extremely big problems to calculate the next iteration.
Probably you made one of the inputs much too large or much too small.
pakk is offline   Reply With Quote
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
