March 25, 2017, 06:53 |
UDF for wind effect
Danial
Rep Power: 9 |
is there any way to define wind stress on water surface by using UDF?
I am using 2D modeling VOF model, free surface water. |
March 27, 2017, 12:23 |
Douaa Al-Assaad
Rep Power: 9 |
I think you can model this as a speed instead of stress, for example set an inlet velocity as a UDF function to model wind flow near the surface (or if the wind is at constant speed then you might not need a UDF), and to monitor stress on the water surface, just define a patch on the surface of the water where you can monitor that. |
Help with unsteady calculation with source/sink UDF | RobV | FLUENT | 1 | November 13, 2016 06:44 |
Help with unsteady calculation with source/sink UDF | RobV | Fluent UDF and Scheme Programming | 3 | March 10, 2016 04:45 |
time dont effect in heat source in udf | weldman | Fluent UDF and Scheme Programming | 0 | December 3, 2012 07:56 |
Simulation with UDF for species mass fraction and velocity profile | virgy | Fluent UDF and Scheme Programming | 8 | February 7, 2012 05:30 |
UDF programming | fullmonty | FLUENT | 5 | June 30, 2011 03:40 |
