UDM segmentation fault.
Old   March 23, 2017, 10:39
Default UDM segmentation fault.
sebastian bergman
Tushar_Telmasre is on a distinguished road
I am trying to learn the use of UDMs.
I read through ansys help and tried to execute define on demand udm.
the code is
UDF to calculate temperature field function and store in
user-defined memory. Also print min, max, avg temperatures.
#include "udf.h"
DEFINE_ON_DEMAND(on_demand_calc)
Domain *d; /* declare domain pointer since it is not passed as an
argument to the DEFINE macro */
real tavg = 0.;
real tmax = 0.;
real tmin = 0.;
real temp,volume,vol_tot;
Thread *t;
cell_t c;
d = Get_Domain(1); /* Get the domain using ANSYS Fluent utility */
/* Loop over all cell threads in the domain */
thread_loop_c(t,d)
/* Compute max, min, volume-averaged temperature */
/* Loop over all cells */
begin_c_loop(c,t)
volume = C_VOLUME(c,t); /* get cell volume */
temp = C_T(c,t); /* get cell temperature */
if (temp < tmin || tmin == 0.) tmin = temp;
if (temp > tmax || tmax == 0.) tmax = temp;
vol_tot += volume;
tavg += temp*volume;
end_c_loop(c,t)
tavg /= vol_tot;
printf("\n Tmin = %g Tmax = %g Tavg = %g\n",tmin,tmax,tavg);
/* Compute temperature function and store in user-defined memory*/
/*(location index 0) */
begin_c_loop(c,t)
temp = C_T(c,t);
C_UDMI(c,t,0) = (temp-tmin)/(tmax-tmin);
end_c_loop(c,t)
This is the same as given in the ansys help.
further i defined a memory location in fluent.
solved the following problem.
A Square aluminium block of lenght 1mm. properties as given in fluent.
left boundry: 600K temperature.
Right boundry: 100K temperature.
solved the problem with time step of 1e-5 for 100 time steps.
now when i am trying to execute on demand the function it is giving me a
segmentation fault. what is wrong here.
As far as i know segmentation fault occurs when code tries to access undefined memory location. I defined 1 user defined memory slot. still it is not working.
what needs to be done.
Please help.
Tushar_Telmasre is offline   Reply With Quote
Old   March 24, 2017, 06:45
pakk will become famous soon enough
You are correct that this error indicates that you are trying to access a memory location that does not exist. The next step is to identiy where in your code this happens.
It could be in three places: C_UDMI(c,t,0), C_VOLUME(c,t), C_T(c,t)
If you remove the line with C_UDMI(c,t,0), do you still get this error?
If you replace C_VOLUME(c,t) by 0.1, do you still get this error?
If you replace C_T(c,t) by 300, do you still get this error?
If the error disappears, you know which line causes the error. And then think about why it could be. If C_T is the problem, are you sure that all cells have a temperature associated?
pakk is offline   Reply With Quote
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
Segmentation fault in SU2 V5.0 ygd SU2 2 March 1, 2017 05:38
UDF with UDM Error: segmentation fault dj1210 Fluent UDF and Scheme Programming 4 November 24, 2016 10:44
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
