Hooking a UDM function.
Old   March 23, 2017, 02:53
Default Hooking a UDM function.
sebastian bergman
Tushar_Telmasre is on a distinguished road
I did write a simple code to save my temperature data in a udm.
#include "udf.h"
real temp;
cell_t c;
Thread *t;
begin_c_loop(c,t)
temp = C_T(c,t);
F_UDMI(c,t,0) = temp;
end_c_loop(c,t)
it is not getting interpreted.
I want to know which macro I need to use to hook this function to fluent.
I want to further define a custom field function with value udm0 and plot it at the end of calculation. The contours of that should be same as the contours of temperature.
Can anyone please have a look and suggest any mistake? also how and where do I hook this UDF?
Tushar_Telmasre is offline   Reply With Quote
Old   March 23, 2017, 03:45
pakk will become famous soon enough
I would use DEFINE_ON_DEMAND. See the help for more info.
pakk is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 10:54
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
