Getting ANSYS 14, Window 10, and Visual Studio 15 to compile UDF's |
March 2, 2017, 03:48 |
Rep Power: 10 |
Hi all, I would like to compile UDF into the Fluent 14 (Window 10).
My system consists of the following: -Window 10 x64 -ANSYS Fluent 14 x64 -Microsoft Visual Studio 2015 -Microsoft .NET Framework 4.5.1 The methods described in "https://www.cfd-online.com/Wiki/Fluent_FAQ#How_can_I_manage_to_compile_my_UDF_with _Windows_7_64bit.3F" function well on Window 7. But such setup does not work on Window 10. Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64). The operation completed successfully. C:\Users\0wner\Desktop ry ken\libudf\win64\3d_host\libudf.dll Anyone face the same problem and how do you solved it? Would you mind to share it? Thank you. |
March 2, 2017, 22:34 |
Rep Power: 10 |
Hi all,I already solved this problem.
You may refer to the link below: https://www.cfd-online.com/Forums/bl...pile-udfs.html It works on Window 10. Last edited by kywong5; March 13, 2017 at 20:32. |
February 3, 2018, 09:56 |
How can I load the UDF code in ANSYS Fluent?
mohammadghasem
hi kywong5
I have the same error When I compiling UDFs, I can build "libudf", but I can't load it. So could you help me or to explain why? my system consists of the following: - Microsoft Windows 10 x64 - ANSYS Fluent 17.0 x64 - Microsoft Visual Studio 2015 Thank you very much! Error: The UDF library you are trying to load (libudf) is not compiled for 3ddp on the curent platform (win64). The system cannot find the file specified. |
February 4, 2018, 13:10 |
Rep Power: 26 |
This error indicates that Fluent thinks that your UDF is NOT compiled, even though you think so. Look carefully after you click 'build' for errors!
