Coupling of Fluent and Rigid Dynamics
Old   February 28, 2017, 06:58
Default Coupling of Fluent and Rigid Dynamics
Julian
Juli is on a distinguished road
Hello everybody,
I'm trying to couple a CFD-Simulation in Fluent with a Rigid Dynamics Simulation. The specific case is simply a rod which has a constant velocity in one end (See picture).
In order to couple the Analyses I want to Export force on the rod after every timestep and Import displacement/rotation of the center of gravity before every timestep.
I have two main problems concerning fluent:
  1. Is it possible to rotate and translate a mesh zone at the same time? How? Preferable with a Profile (I'm working at a university's computer and there it is not possible to compile the udfs nor easy to do software changes)
  2. Is it possible to read a file with displacements and change the rotation and translation in the Profile/UDF before each timestep?
Exporting the force on the rod is no problem.
I'm happy for every help.
Thanks a lot in advance.
If somebody here is also skilled on the mechanical side please tell me, there I will also need help.
Juli is offline   Reply With Quote
multiple objects in rigid body simulation using FLUENT Daniel_Khazaei FLUENT 1 August 21, 2016 13:14
Modeling of Flexible, rigid and fixed cylinder in Fluent or CFX bestniaz FLUENT 0 October 7, 2015 01:12
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 12:24
rigid body's motion with DOF in Fluent tsh850227 FLUENT 0 April 28, 2014 11:03
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 13:56
