February 27, 2017, 01:48 |
how to generate general wall function
Neda S. R. Nikou
Rep Power: 10 |
Hi every body
I have written a 3D Incompressible NS solver including k-e, Smagorinsky models to simulate turbulent flow in different test cases. I do not know how to generate general code for the wall function part which is applicable for any test cases. I have problem with corners and walls. of course, developed code was solved for the the flow in duct and pipe, dambreak. but each have different wall function part and is not applicable for any test cases. I would be grateful if you could help me. |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
