February 21, 2017, 14:34 |
Average Temperature
Rep Power: 12 |
I am simulating a sub-channel flow (in a nuclear reactor), so I have 4 domains (fuel, gap, clad and fluid). I have a volumetric heat generation into the fuel and I and to calculate the fluid average temperature by using a UDF. I wrote something like that: #include "udf.h" DEFINE_TEMPERATURA(temp_ave_fluid) { Domain *d; cell_t c; Thread *tc; ind ID = 30; */ ID of the domain fluid d = Get_Domain(1); real volume = 0.0; real temper = 0.0; real temperature_fluid; tc = Lookup_Thread(d,ID); begin_c_loop(c,tc) { volume = C_VOLUME(c,tc); temper += C_T(c,tc)*C_VOLUME(c,tc); vol_tot += volume; tsum += temper } end_c_loop(c,tc) temperature_fluid=tsum/vol_tot; printf("\n Temperature sonde: %e K \n , temperature_fluid); } But I can not interpret the UDF, Fluent says: "unterminated string or character constant" "possible real start of unterminated constant" "line 7: parse error" Could someone helps me? Please Thanks |
February 22, 2017, 08:53 |
Kevin
Rep Power: 10 |
Not sure what line 7 is in your code, but a couple of things:
1: I've never heard of the DEFINE_TEMPERATURA macro. Not sure what it is or what it does, if it even exists. 2: If you want to just calculate and print a variable, I'd suggest using DEFINE_ADJUST. 3: There's a spelling error in "Ind ID = 30;". It should read "Int ID = 30;". 4: Are you trying to calculate a volume-weighted average temperature? If so, don't need a UDF for that, you can just create a monitor for it. 5: If you do absolutely want a UDF for it, I think you're making a calculation error, as you're summing C_T(c,ct)*C_VOLUME(c,ct) twice. I'd suggest to just write "volume += C_VOLUME(c,ct) and delete the vol_tot and tsum calculations/variables. But perhaps these suggestions are irrelevant as it could be that I misunderstand what you're trying to do. I understand it's a nuclear reactor, but I figure your fluid is in a separate domain/volume from the fuel rod and cladding, right? So is it the coolant's average temperature you want? |
February 22, 2017, 15:47 |
Rep Power: 12 |
Dear Kevin,
Thank you for your response. Actually I did some mistakes, thanks. I really need to calculate the average temperature by UDF to use the information to perform a feedback to the fuel. I am a little lost in UDF, I don't find a lot o material on internet to learn. If I try to use DEFINE_ADJUST, Fluent says that I have only one argument, but it's not a error, and I also tried with DEFINE_ADJUST (temp_ave_fluid, domain). Today my code is: #include "udf.h" DEFINE_EXECUTE_AT_END(temp_ave_fluid) { Domain *d; cell_t c; Thread *tc; Int ID = 30; d = Get_Domain(1); real volume = 0.0; real temper = 0.0; real temperature_fluid; tc = Lookup_Thread(d,ID); begin_c_loop(c,tc) { volume += C_VOLUME(c,tc); temper += C_T(c,tc)*C_VOLUME(c,tc); } end_c_loop(c,tc) temperature_fluid=tsum/vol_tot; printf("\n Temperature sonde: %e K \n , temperature_fluid); } But I keep having the same problems. Thanks one again, Felipe |
February 23, 2017, 08:18 |
Kevin
Rep Power: 10 |
Well, you need to close the string in your printf statement, as now you've only got the opening quotation mark ", but no accompanying closing one. So put a " after the second \n in the printf statement.
Also, I noticed in your old code you used */, but that signals end of comments. Start of comments is indicated by /*. But outside of the syntax, what is it you're really trying to do? Because the macro to use depends on what you want to accomplish. I suggested DEFINE_ADJUST for just outputting information, but perhaps you need another one if you want to feed your volume weighted average temperature back to your simulation. |
March 7, 2017, 07:28 |
Rep Power: 12 |
Kevin,
Thank you very much for your corrections. But it still not working... "#include "udf.h" DEFINE_ADJUST(temp_ave_fluid) { Domain = Get_Domain(1); cell_t c; Thread *tc; real volume = 0; real temper = 0; real temperature_fluid; tc = Lookup_Thread(domain,fluid); begin_c_loop(c,tc) { volume += C_VOLUME(c,tc); temper += C_T(c,tc)*C_VOLUME(c,tc); } end_c_loop(c,tc) temperature_fluid=temper/volume; printf("\n Temperature sonde: %e K \n , temperature_fluid"); }" And actually I have serious problems when Fluent try ti read it: "cpp -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/client/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/multiport/src" -I. -DUDF ONFIG_H="<udfconfig-host.h>" "C:\Documents and Settings\Lasme\Desktop\UDF_Tmedio_fluido\qv_cos_03 _copia\Tmedio_fluido3.c" C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c:3: macro `DEFINE_ADJUST' used with just one arg Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 5: parse error. Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 6: parse error. Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 7: parse error. Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 8: parse error. Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 9: parse error. Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 10: parse error. Error: C:\\Documents and Settings\\Lasme\\Desktop\\UDF_Tmedio_fluido\\qv_co s_03_copia\\Tmedio_fluido3.c: line 11: tc: undeclared variable MPI Application rank 0 exited before MPI_Finalize() with status -1073741819 The fl process could not be started." Do you not what it's wrong now? Please Thanks, Felipe |
May 7, 2017, 10:40 |
Rep Power: 10 |
Did you try to go over the look up function directly?
t average, udf |
heat transfer coefficient value in floefd | jason kid | FloEFD, FloWorks & FloTHERM | 10 | October 16, 2016 17:55 |
Anys Average temperature | apo | FLUENT | 2 | November 4, 2014 13:31 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 05:03 |
average interior temperature less than the operating temperature | Naher | FLUENT | 4 | April 1, 2011 00:14 |
