February 14, 2017, 05:48 |
solution_initialization_problem_and_UDF
Francesco Tronci
Hi guys,
I'm a new member and I try to simulate CO2 adsorption process in a adsorbent bed (column). I use a udf code written by another person (fluent 16.2) . When I run his simulation on my pc with fluent 16.0 it run correctly but when i set up my very similar simulation a have a problem during initialization in particular this one: ================================================== ============================ Node 0: Process 5068: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 1: Process 8692: Received signal SIGSEGV. ================================================== ============================ MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started. Can you help me, please? Thanks a lot |
March 29, 2017, 07:06 |
Same here
DENG Weriping
Rep Power: 11 |
Did you resolve this problem? I faced the same problem that the error occured after initialized FLuent.
If you dealed with this problem, please taught me how to solve it. |
fluent, udf |
