UDF code help solve reaction rate equation palm oil
Old   February 13, 2017, 11:34
Default UDF code help solve reaction rate equation palm oil
cyril
zirkov is on a distinguished road
Hello everyone,
I am trying to write a UDF code to import it into Ansys Fluent.
Actually, the reason of writing a UDF code is that there is not in fluent data base palm oil namely Triglycerides for reactants and Alkanes for products.
So I have to write a UDF code.
Firstly, I have already a udf code (DEFINE_PROPERTY) for chemical properties for each triglycerides, each alkanes and some fatty acids like density, conductivity, specific heat capacity, viscosity ect..
I am here to help me how to write the reaction kinetic rate for each equation. I need to find the rate k1 to k8 reactions. For each reactant and each product, I don't have the concentration.
I have found a UDF example but I'd like to know if it's a good example to take for writing a UDF code with my case (palm oil)
#include "udf.h"
#define K1 2.0e-2
#define K2 5.
DEFINE_VR_RATE(vol_reac_rate, c, t, r, mole_weight, species_mf, rate, rr_t)
real s1 = species_mf[0];
real mw1 = mole_weight[0];
if (FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous)
*rate = K1*s1/pow((1.+K2*s1),2.0)/mw1;
else
*rate = 0.;
*rr_t = *rate;
I have sent in attachment a file with my kinetic equation reaction.
Is it possible to use the previous code UDF for my case, otherwise do you have any idea ?
Thank you for your help.
zirkov is offline   Reply With Quote
How to add Arrhenius Reaction Rate to energy equation? Zack OpenFOAM Programming & Development 2 March 23, 2022 08:34
using rate equation for volumetric reaction byronsmith FLUENT 4 April 14, 2019 13:28
udf for multiple reaction rate monababaei Fluent UDF and Scheme Programming 3 November 5, 2018 08:30
Langmiur equation as a reaction rate in fluent borhan_sd@yahoo.com FLUENT 0 June 1, 2013 05:17
UDF rate equation alp FLUENT 3 November 8, 2007 13:39
