Encountered syntax error when trying to compile udf
Old   February 8, 2017, 04:17
Default Encountered syntax error when trying to compile udf
dylpeng is on a distinguished road
Hello friends,
This is my first time posting on this forum so please be gentle.
I've been trying to compile my UDF but this error keeps popping up.
..\..\src\upper.c(48) : error C2143: syntax error : missing ')' before ';'
..\..\src\upper.c(48) : error C2059: syntax error : ')'
..\..\src\upper.c(49) : error C2143: syntax error : missing ')' before ';'
..\..\src\upper.c(49) : error C2059: syntax error : ')'
..\..\src\upper.c(59) : error C2143: syntax error : missing ')' before ';'
..\..\src\upper.c(59) : error C2059: syntax error : ')'
Below is my code to be compiled...
#include "udf.h"
#include "mem.h"
#include "math.h"
#define domain_ID 1;
#define zone_RPA 7;
#define zone_LPA 6;
real Q_3D_rpa = 0;
real Q_3D_lpa = 0;
DEFINE_EXECUTE_AT_END(massflowrate)
	Domain *domain;
	face_t f_RPA;
	face_t f_LPA;
	Thread *f_thread;
	domain = Get_Domain(domain_ID);
	f_thread = Lookup_Thread(domain,zone_RPA);
	begin_f_loop(f_RPA,f_thread)
		Q_3D_rpa += F_FLUX(f_RPA,f_thread);
	end_f_loop(f_RPA, f_thread)
	printf("Mass Flow Rate at RPA: %f\n",Q_3D_rpa);
	f_thread = Lookup_Thread(domain,zone_LPA);
	begin_f_loop(f_LPA,f_thread)
		Q_3D_lpa += F_FLUX(f_LPA,f_thread);
	end_f_loop(f_LPA, f_thread)
	printf("Mass Flow Rate at LPA: %f\n",Q_3D_lpa);
	Q_3D_lpa = 0.;
	Q_3D_rpa = 0.;
Any advice is greatly appreciated!!
Thank you!
dylpeng is offline   Reply With Quote
Old   February 8, 2017, 04:50
pakk will become famous soon enough
The code that you posted here has 43 lines.
The errors that you posted here, indicate that there is a mistake on the 48th line. That line does not exist in the code that you show here.
So for some reason, Fluent is trying to compile a different code than the one you posted here. Can you check if this is really the code that you are asking Fluent to compile? Maybe you looked in the wrong folder?
pakk is offline   Reply With Quote
Old   February 8, 2017, 04:52
Hi pakk!
I deleted some of my comments before posting onto the forums.Haha! The error occurs at
Old   February 8, 2017, 04:59
OK, that makes it clear.
That line is
What is "domain_ID"? You #defined it as "1;". So after replacing that, your code becomes
domain = Get_Domain(1;);
You see, after the 1 there is a ; but the compiler still needs a ). That explains the error message that you saw.
The real problem is that you added a ";" after your #defines. So make it:
#define domain_ID 1
#define zone_RPA 7
#define zone_LPA 6
Old   February 8, 2017, 05:00
Oh gosh, such a silly mistake! Thank you!
Old   February 8, 2017, 05:02
I expect that every experienced c-programmer at least once made this mistake. So I would not call it silly.
Old   December 25, 2017, 07:27
Default UDF error missing ')'
Arun raj.S
arunraj is on a distinguished road
#include <stdio.h>
#include "udf.h"
# define UDF_FILENAME "udf_loc_velo_acc"
# define Temp_File "mytemp"
/* read current location,velocity and accelerator from file */
static void
read_loc_vel_acc_file (real *loc1, real *vel1,real *acc1)
FILE *fp = fopen(Temp_File, "r");
if (fp != NULL)
float read_loc1, read_vel1, read_acc1;
fscanf (fp, "%e %e %e", &read_loc1, &read_vel1, &read_acc1);
fclose (fp);
*loc1 = (real) read_loc1;
*vel1 = (real) read_vel1;
*acc1=(real) read_acc1;
Message ("\nUDF read viv: y_vel = %f, acc = %f, loc(m)= %f\n",
*vel1, *acc1, *loc1);
else
*loc1 = 0.0;
*vel1 = 0.0;
*acc1 = 0.0;
Message("\nThe first reading of udf_loc_vel_acc_file\n");
/* write current location, velocity and acceleration into file */
static void
write_loc_vel_acc_file (real loc, real vel, real acc)
FILE *fp = fopen(UDF_FILENAME, "a");
if (fp != NULL)
fprintf (fp, "%e %e %e\n", loc, vel, acc);
fclose (fp);
else
Message ("\nWarning: cannot write %s file", UDF_FILENAME);
/* write current location,velocity and acceleration into temp_file */
static void
write_loc_vel_acc_file2 (real loc, real vel, real acc)
FILE *fp = fopen(Temp_File, "w");
if (fp != NULL)
fclose (fp);
else
Message ("\nWarning: cannot write %s file", Temp_File);
DEFINE_CG_MOTION(viv, dt, cg_vel, cg_omega, time, dtime)
#define DELTA 0.5
#define BETA 0.25
#define K_SPRING 22.406
#define MASS 4.864
#define xi 0.0054
real wn=sqrt(K_SPRING/MASS);
real CC=2*xi*wn*MASS;
/*fn=2.92745*/
/*mass ratio equaul 2.4*/
real loc,vel,acc,loc1,vel1,acc1;
real a0,a1,a2,a3,a4,a5,a6,a7,keff,reff;
static int id1=5; /* Face ID of the cylinder */
static real f_glob[3]; /* Total forces (global) */
static real m_glob[3]; /* Moment (global) */
static real x_cg[3]; /* CG location */
static real force[3];
int i=0;
Thread *tf1;
Domain *domain = Get_Domain(1);
tf1 = Lookup_Thread(domain, id1);
a0=1/(BETA*dtime*dtime);
a1=DELTA/(BETA*dtime);
a2=1/(BETA*dtime);
a3=0.5/BETA-1;
a4=DELTA/BETA-1;
a5=0.5*dtime*(DELTA/BETA-2);
a6=dtime*(1-DELTA);
a7=DELTA*dtime;
keff=a0*MASS+a1*CC+K_SPRING;
/* reset velocities */
NV_S (cg_vel, =, 0.0);
NV_S (cg_omega, =, 0.0);
if (!Data_Valid_P ())
return;
/* Get CG position */
for (i=0; i<ND_ND; i++) x_cg[i] = DT_CG(dt)[i];
/* compute force on cylinder */
force[1] = 0.0;
Compute_Force_And_Moment(domain, tf1, x_cg, f_glob, m_glob, TRUE);
force[i] = f_glob[i];
/*read data calculated in the former step*/
read_loc_vel_acc_file (&loc1, &vel1, &acc1);
/* compute response of cylinder by newmark method*/
reff=force[1]+MASS*(a0*loc1+a2*vel1+a3*acc1)+CC*(a1*loc1+a4*vel 1+a5*acc1);
loc=reff/keff;
acc=a0*(loc-loc1)-a2*vel1-a3*acc1;
vel=vel1+a6*acc1+a7*acc;
Message ("\nUDF of viv: time = %f, y_vel = %f, acc = %f, loc(m)= %f\n",
time, vel, acc, loc);
write_loc_vel_acc_file (loc, vel, acc);
write_loc_vel_acc_file2 (loc, vel, acc);
cg_vel[1] = vel;
this is the udf i am trying to load and I am getting this message from fluent. Kindly help me
"Copied E:\Arun\Tandem\Tandem fluent\free oscillations\Naturally oscillating cylinder zhang/E:\Arun\Tandem\Tandem fluent\free oscillations\Naturally oscillating cylinder zhang\udf_loc_velo_acc.c to libudf\src
udf_names.c and user_nt.udf files in 2ddp are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v180\fluent"\fluent18.0.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp")# Generating ud_io1.h
udf_loc_velo_acc.c
..\..\src\udf_loc_velo_acc.c(107) : error C2143: syntax error : missing ')' before 'constant'
..\..\src\udf_loc_velo_acc.c(107) : error C2059: syntax error : ')'"
arunraj is offline   Reply With Quote
Old   January 2, 2018, 11:37
The compiler indicates that that the error is on line 107.
If I counted correctly, this line is:
I see one mistake there. One thing looks different than the rest. Can you see it?
Old   January 2, 2018, 11:42
Arun raj.S
Yes mate.. space must be removed.. thank you for your reply..
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Syntax error UDF Fluent13 SteveGoat ANSYS 0 May 17, 2012 05:13
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 14:24
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 10:48
Compile UDF with a C++ compiler Luca FLUENT 7 December 27, 2005 00:05
