Density UDF Divergence
Old   January 11, 2017, 16:25
Default Density UDF Divergence
Baden is on a distinguished road
Hello all.
I am attempting to use a UDF to define a density that changes every iteration. However, the code I am using results in a x-momentum divergence error upon the first iteration. I created a fresh Fluent setup with the only changes from default being using the transient solver and the following UDFs for initialization and material density (hooked correctly of course):
#include "udf.h"
#define thread_ID 2 /* thread ID of the fluid cell zone */
#define rho_water 997 /* density of water */
DEFINE_INIT(initialize, d)
    Thread *t = Lookup_Thread(d, thread_ID);
    cell_t c;
    begin_c_loop(c, t)
        C_UDMI(c, t, 0) = 1;
    end_c_loop(c, t)
DEFINE_PROPERTY(density, c, t)
    real Y_water = C_UDMI(c, t, 0);
    real rho_f = rho_water * Y_water;
    return rho_f;
Obviously, the code is simplified from what I am actually using, but the above code is adequate to replicate my problem. What is odd is that the code works if I change the first line of the DEFINE_PROPERTY() macro to:
real Y_water = 1.0;
I honestly have no idea what the problem is. Any help would be appreciated.
Baden is offline   Reply With Quote
Divergence detected in AMG solver: k when udf loaded google9002 Fluent UDF and Scheme Programming 3 November 8, 2019 00:34
Interpret-Real Gas UDF ndabir Fluent UDF and Scheme Programming 3 November 18, 2015 08:29
Error using UDF to modify density NRD FLUENT 1 July 13, 2011 08:35
density UDF problem wanghuiru FLUENT 0 August 18, 2008 08:35
UDF: Density Cell Gradient Vector Macros matteo FLUENT 0 December 1, 2007 13:14
