January 6, 2017, 16:13 |
How to display w/m³ in post processing?
Rep Power: 10 |
Hello everybody,
I am considering a tube flowed through by water. In the tube, i applied a source term (w/m³) in the cells by a UDF. After running the process, I see the results of temperature distribution which seems to be correct. Is it possible (and how) to visualize the joule heat distribution (coll zone conditions in w/m³)? Best regards h0rst |
January 10, 2017, 06:01 |
KirMaks
Rep Power: 10 |
Hallo,
You can put You source into UDM and plot its contours. It will be also possible to use volume intgrals to get the total power then. Best regards, Maks |
wind turbine - post processing | er_ijaz | FLUENT | 0 | September 30, 2013 06:28 |
post processing for CEL expressions | Niru | CFX | 0 | May 10, 2013 14:13 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 07:21 |
[OpenFOAM] is parallel processing available in parafoam for post processing? | sachinlb | ParaView | 1 | August 14, 2012 10:52 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 21:51 |
