January 5, 2017, 16:57 |
Parameters Changing Based on UDF
Rep Power: 10 |
Hello all.
I am modeling species transport through a porous medium with anisotropic diffusion. I am attempting to define the diffusion by changing the matrix components in the image below to user-defined parameters. I want the parameters I define in the matrix to change each iteration according to a UDF (using RP_Set_Real), however, any parameter I link to a UDF does not show up in the parameter list for the matrix components. Is there any solution to this problem? |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 13:35 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
UDF for modifying porous jump parameters | twcp0104 | Fluent UDF and Scheme Programming | 0 | December 15, 2016 08:06 |
UDF to read cell var. based on particle position | CeesH | Fluent UDF and Scheme Programming | 2 | February 24, 2014 11:21 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
