UDF compiling problem
Old   December 26, 2016, 22:38
Question UDF compiling problem
manar
manar is on a distinguished road
Hello guys
I am trying to compile 2 UDF files for a case that is built in another computer (64-bit) ; when I try to compile in my computer ( win 7 - 64 bit - ansys student 17.1 - visual studio 2010) the UDFs I get these errors :
udf_names.c and user_nt.udf files in 2ddp are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v171\fluent"\fluent17.1.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp")# Linking libudf.dll because of user_nt.udf udf_names.obj air-RGM.obj air.obj
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation. All rights reserved.
LINK : fatal error LNK1104:
Done.
when I check the log in 2ddp I found this :
jMicrosoft (R) C/C++ Optimizing Compiler Version 16.00.30319.01 for x64
NMAKE : U1077: ?C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\BIN\amd64\link.EXE"?
Stop.
I tried to define the executable file (LINK.exe)in the system variables but the errors remain standstill , is it the version of the visual studio ? , What could be the cause and how to fix it ? any thoughts !
manar is offline   Reply With Quote
Old   December 27, 2016, 07:28
manar
I re-installed VS but this time I installed VS 2015 (community) , I got this error when I load the UDF files :
'cl' is not recognized as an internal or external command , operable program or batch file .
NMAKE : U1077 : 'cl' return code '0x1'
Please any help with this one ?
Old   January 3, 2017, 05:26
pakk will become famous soon enough
Is this the first time that you try to compile UDFs on your computer, or do other UDFs work?
pakk is offline   Reply With Quote
Old   January 12, 2017, 02:47
manar
Acually it is a fluent and visual studio compatibility problem .
Old   January 12, 2017, 08:56
Howard
twcp0104 is on a distinguished road
Done.
Usually when I get this, what I do is close fluent (or unload the library libudf), delete the libudf folder in your case folder, and try to compile again. Usually works.
twcp0104 is offline   Reply With Quote
fluent - udf
Problem with UDF for CG Circular Motion luthlau Fluent UDF and Scheme Programming 1 September 16, 2016 03:08
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
Problem with compiling UDF in Fluent amojodi Fluent UDF and Scheme Programming 4 April 14, 2015 10:01
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 11:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 04:21
